RV.Net Open Roads Forum: General RVing Issues: Good Sam credit card fuel limits
 > Good Sam credit card fuel limits
mich800
Pontiac, MI
Posted: 09/09/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
westernrvparkowner wrote:
fj12ryder wrote:
beemerphile1 wrote:
When using a credit card without a signature the card company limits how much they will be liable for if the card is bad/stolen. Some gas companies will cut you off at that limit because anything over comes out of their pocket.
The limit the gas stations impose have nothing to do with credit card limits They are arbitrary amounts set by the stations, not the CC companies. That limits their losses in case of drive offs.
It technically isn't a classic drive off, but what happens is the fuel station sends your credit card company a preset amount to determine if the card is active. They don't have a constant live feed during fueling to say "stop the pump, Fred has reached his card limit or the checking account linked to his debit card is going to be overdrawn when the next gallon of gas is pumped". When the pump shuts off at the preset limit, that amount is applied to your card account and any subsequent pumping restarts the process. If you don't have enough credit limit or money in your debit card checking account to cover the station limit, your card will be denied.
Yes very true. I use a Paypal debit often because I have some customers send money that way. Even though you may only see the $1 transaction until finalized the pump is actually performing an authorization for a predetermined max amount. So even if you are only going to put $20 in the pump basically reserves an amount say $75. If you don't have the sufficient available credit it fails. After the transaction is complete the pump captures the actual amount. This amount can be applied to your card immediately or several days later. Those that deal with credit/debit card transactions will understand the difference between a captured event or an authorized event.
Edd505
Elephant Butte, NM
Posted: 09/09/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 debit cards and both shut off @ $100.00 With 40 gallon tank and 80 gallon transfer it's frequently over $200. To get around this just pay cash. Watch the cashier when you hand them 200-250 and say pump 3.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
beemerphile1
Ohio
Posted: 09/09/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, with a signature the card company accepts full risk, without a signature they limit the risk to a set amount, exceed that amount and the station can get burned.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
fj12ryder
Platte City, MO
Posted: 09/09/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
So why do you get different limits at different stations using the same card? It's set by the stations, otherwise all stations would have the same limit on the same card, and they don't.
Howard and Peggy
"Don't Panic"
rhagfo
Portland, OR
Posted: 09/09/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
We don't ever use debit cards at fuel stations, charge card only, they have the greatest protection against fraud.
beemerphile1
Ohio
Posted: 09/09/19 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Of course the cutoff is set by the station depending on how much risk they are willing to assume. Higher volume stations could also get a higher guarantee from the card company, We aren't privy to those negotiations.
fj12ryder
Platte City, MO
Posted: 09/09/19 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Which is the answer to the question asked by the OP, and was replied to by me and several others: the gas station sets the limits.
beemerphile1
Ohio
Posted: 09/10/19 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
The station either abides by the card company limits or sets different limits.
The fact is; the issue is caused by limits set by the card company on non-signature transactions.
You don't want the limit? Take a walk into the the store and sign, then it is a different type of transaction.
hot rod
muskegon,mi
Posted: 09/11/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
I've had my card denied for the second or third pumping with $1000's of credit left on the card, so that explanation doesn't hold water. For that reason I always carry a second card when traveling
westernrvparkowner
montana
Posted: 09/11/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Yes, there are also many other fraud protections built into both your credit card limits and the fuel stations credit card processing software. Neither you, the fuel station or the credit card company want a thief to be able to fuel his vehicle and the vehicle of a few dozen friends. Sometimes there is a thin line between protection and convenience.
