RV.Net Open Roads Forum: Fifth-Wheels: Stuck along a fence
 > Stuck along a fence
pyoung47
MO
Posted: 09/08/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty sure a tow company would just runs line through the wheels and drag it sideways enough to get it out.
fj12ryder
Platte City, MO
Posted: 09/08/19 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
That seems unlikely if it is in such a position that it can be simply pulled out. Why make more work when it's easier to just hook up and pull it out?
There's no pictures, no measurements, no real reason to jump to such conclusions.
Howard and Peggy
"Don't Panic"
Sdbousson
Newnan GA
Posted: 09/08/19 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
All is well! The small baby steps were successfully in moving us off the fence. What REALLY sealed the deal was a preciously wonderful person from Coweta Fire Department Fireman Fretwell who happened by at hour 3 of 2nd day “getting off the fence, who helped out IMMENSELY and gave us his straight ahead spot for the night tonight. We find a more appropriate spot tomorrow to park in. Real lessons learned? Do not underestimate the swing of the back. Do NOT think you can fit without using real math. Understand the truck cannot move beyond a 45 degree angle is pivot without pressing on and breaking the back of the truck window out. (Day one) keep a level head and a sense of humor. Know when to ask for help!
Once again thank you all for your patience and help. YOU ROCK! Maybe one day WE will be able to help others!
JRscooby
Indepmo
Posted: 09/08/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Why in the wide world of sports would you get a tow company involved?
whiteeye42
Rock Springs Wyoming
Posted: 09/08/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
and i don't think pulling it from the side would be very good for the wheels and axles or for that matter the frame not a good idea
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
winniman
muskoka Ontario
Posted: 09/08/19 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't have a set, buy a pair of walkie talkies so you can communicate with your spotter. It will help a lot, and cut down on the wildly swinging arms and yelling that make watching newbies set up so much fun. Glad it ended well. Cheers.
pyoung47
MO
Posted: 09/09/19 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Re: Pulling sideways
Not something I would relish. My understanding was that it was unable to be moved without damage. Pulling it a few inches sideways would likely cause no damage. I’ll admit it would make me cringe, but so does a root canal.
agesilaus
North Florida
Posted: 09/09/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
If this was a regular hog wire fence it would be a lot cheaper to cut the fence roll it up, pull up a couple of fence posts, move the fiver. Then put the posts back in and re-attach the fence. Than to repair damage to the fiver or call a wrecker.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Braces
Alabama
Posted: 09/09/19 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Surely you expect the "sideways puller" was being sarcastic. Why not recognize humor?
ford truck guy
Pennsylvania
Posted: 09/10/19 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I was in a truck stop last year and saw a guy pulling a brand new camper about 2" off the wall, the wrong way....
I said to my wife " I hope he doesn't plan on turning into a spot there".... With that he turned a hard left into the spot...... It was sad watching and listening to the crunch... I was jogging to them, but did not make it in time...
Always know your position.. go to an empty lot and PRACTICE
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
