RV.Net Open Roads Forum: Tech Issues: Looking for Fridge Suggestions
 > Looking for Fridge Suggestions
SGTJOE
Utah
Posted: 09/08/19 11:56am Link  |  Quote  |  Print  |  Notify Moderator
I just had my old Dometic NDR1292 removed and had a Magic Chef installed. I was really happy until I found the User's Manual and read "not designed to be installed in an rv or used with an inverter" Now if this wasn't enough it also stated "ambient Temperature below 50"F or above 85 F will hinder the performance of the appliance. Working with dealer for not telling me.
So I'm looking for suggestions as to what residential fridge would work I need to be able to have a counter depth one where I can open the door to a max of 50 inches. Width 32 inches and height not to exceed 62 inches.
For those of you who have residential fridges in your RV can you send me the make and model number. I might be able to work with the height.
My MH is a 2001 National Tradewinds model 7390.
2001 Trade Winds 7390
Toad 03 Grand Am
2oldman
Ca
Posted: 09/08/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
I'd leave it, and take those warnings as lawyer-speak. That refer doesn't know the difference between shore power and inverter, unless it's a really crappy inverter.
ScottG
Bothell Wa.
Posted: 09/08/19 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
X2. They write that stuff simply because they have not evaluated it and just want to CYA.
No way I would just replace it.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
rk911
Wheaton IL
Posted: 09/08/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
i agree but the "murphy" in me suggests you continue to plan to replace it when and if failure occurs. pre-planning now will save grief and anxiety later. purchasing anything in a hurry is never a good idea.
we have a Westinghouse french door/lower freezer but it is too big for your space.
'73,
rich, n9dko
If Jimmy cracks corn and nobody cares then why does he keep doing it?
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Matt_Colie
Southeast Michigan
Posted: 09/08/19 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
SGTJOE wrote:
I just had my old Dometic NDR1292 removed and had a Magic Chef installed. I was really happy until I found the User's Manual and read " Now if this wasn't enough it also stated "ambient Temperature below 50"F or above 85 F will hinder the performance of the appliance. Working with dealer for not telling me.
Sgt Joe,
Were I you, I would leave what you have right where it is....
Because: (Let's tackle that first paragraph)
It is not designed to be installed in a RV because 5ers and TT bounce down the road and they never included vibration in their testing. The back of some Cs can get rough, but if your Tradewinds got that rough, you would have to plan to collect the dishes at every stop.
Or used with an inverter....
If you have enough inverter to get the pump (compressor) started as fast as line power, you have no problem. If you are wondering, open the back side panel and have someone shift the temperature control until it starts. If it starts right up, you are good. You probably have enough house bank (2*GC2 is good) and a 1500+VA inverter. You are good there.
The 50° and 85° are another issue that won't matter much. The 50° is probably where the automatic defrost won't work and the 85° just means it will have to work harder and maybe the ice cream will be soft.
Now, there is a little Gotcha here....
RV reefers are all cooled by a rear coil system and outside air that comes in the back panel and goes out the roof vent. No residential is made that way these days. The cooling is done on the sides of the unit, so you can't build it in tight. It will want an inch or more of clear space on both sides that is open to the living space. This also means that the outside air can come around the sides of the installed unit. That, you have to figure out on your own because I can't see what you have there.
You may also have to invent some way to keep the door(s) closed.
I have had good success with three installations (after the first that was not so good, but still worked).
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
SGTJOE
Utah
Posted: 09/08/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Matt, thanks for all the positive info, I sure can use that about now. Where I am at home in Saint George, Utah we are at around 100-103 degrees for now until winter sets in. I turned the Magic Chef back on today and set the freezer and fridge at the coldest setting, will check it out later tonight. The MH sits beside my house with 50amp hook up.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 09/08/19 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
I would invest in a 1000w PSW inverter to power it if you dry camp often. Otherwise I would not worry about doing anything different.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
SGTJOE
Utah
Posted: 09/08/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Folks I have a Freedom 458 series combi inverter/charger, it is a 2000 watt, is this good for running the residential fridge down the road?
Is this a sine?
2oldman
Ca
Posted: 09/09/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
No, a google search says it's a mod sine.
stage
Weirsdale, FL, USA
Posted: 09/09/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
I installed a Magic Chef about a year and a half ago in our class a and it is still going strong. Hands down the best mod I ever did. I did install a 2000w psw inverter but only because I didn't have one already.
2004 Four Winds Hurricane 29d
1997 Jeep Wrangler toad
2016 Ford Edge toad
