RV.Net Open Roads Forum: Predator 3500 - surge capability while in eco mode?
 > Predator 3500 - surge capability while in eco mode?
DSchmidt_2000
Ventura
Posted: 09/08/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone seen any videos or performed any tests showing how well the Predator 3500 handles surge loads while in eco mode?
I already own a Yamaha EF2000is but it struggles to start our fridge and/or freezer in eco mode. I'm hoping the Predator 3500 has much better surge capability that I could leave it eco mode for the low noise and fuel savings but reliably start these two units up.
Because of lawsuits, Edison is saying they could turn power off for days when it's dry and windy out. Figure I should get ready.
Thanks
pianotuna
Regina, SK, Canada
Posted: 09/08/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
2000 vs 3500 There is the answer.
Regards, Don
GordonThree
Northern Michigan
Posted: 09/08/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Check the instructions. In my Yamaha manual in expressly states not to use Eco mode when operating compressors.
Hopefully the HF manual addresses the issue.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
Home Skillet
Pearland Texas
Posted: 09/08/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
There's a reason for the ECO Mode, for those that aren't running a heavy load.
You can't have both.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
DSchmidt_2000
Ventura
Posted: 09/08/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
From the replies so far it looks like nobody does surge testing anymore. Many years ago people did, me included with my Yamaha.
Hopefully someone will have some test data to share.
SidecarFlip
SE Michigan
Posted: 09/08/19 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Had a Yamaha 2800I, a Honda 2000 and now a Champion 2500, none of them will take a surge load in ECO.
Don't believe the Pred will either. The circuitry is not designed for a surge load in ECO mode. ECO (quiet mode) is all about low draw applications, like charging your house batteries or powering a light or 2 and that is it.
If you think they will, you are in for a rude awakening. None will.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
SidecarFlip
SE Michigan
Posted: 09/08/19 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Additionally, glad I don't live where you live. never a power issue here.
DSchmidt_2000
Ventura
Posted: 09/09/19 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
One data point in. Guy on another forum said "It starts my 13.5btu AC unit without any struggle at all in eco mode. The pitch of the engine barely changes."
TurnThePage
North ID
Posted: 09/10/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Here's another potential data point. My Champion 3400 (similar size to the Predator) also barely notices when my 13.5BTU A/C compressor turns on.
2015 Ram 1500
2004 Pioneer 18T6
72cougarxr7
Northern NY
Posted: 09/10/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I will second the above post, got a Champion 3400 a couple months ago, and it starts my 13.5k ac unit in eco mode no problem, same with the microwave. The 3000+ class inverters seem to handle surge loads better than the 2000 class.
