RV.Net Open Roads Forum: Fifth-Wheels: Hydraulic fluid for Lippert Ground Control
 > Hydraulic fluid for Lippert Ground Control
Campinfan
Washtenaw County, Michigan
Posted: 09/08/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, I know very little about hydraulic systems. My reservoir for my auto leveling system is below the fill line. Lippert said it was ok but I want to add some fluid because it is about 6 inches below the fill line. Are all hydraulic fluids the same? I am not sure what I need to buy. I may just have to call Lippert to see.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
enblethen
Moses Lake, WA
Posted: 09/08/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Here is from one of their owner's manuals.
Fluid Recommendation Automatic transmission fluid (ATF) with Dexron®III or Mercon®V or a blend of both is recommended by Lippert Components, Inc. For a list of approved fluid specifications, see TI-188. To obtain this Technical Information sheet online, go to documents/ti-188-hydraulic-operation-fluid-recommendation. Look for TI188: Hydraulic Operation Fluid Recommendation within the listings. NOTE: In colder temperatures (less than 10° F) the jacks may extend
If you have your owner's manual it should show for your specific system.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
azdryheat
Tucson, AZ
Posted: 09/08/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Is the level low with slides and leveling jacks retracted? If yes, then fill to line.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Super_Dave
Harrisville, UT
Posted: 09/08/19 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
If jacks are down the reservoir shows low. Don’t make my mistake and add fluid. It makes a huge mess.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
DutchmenSport
Indiana
Posted: 09/09/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Click here. Go to page 267 in the PDF.
laknox
Arizona
Posted: 09/09/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Maybe this would be a good time to add some of the additive that LCI recommends, even if Campinfan isn't having the "popping" issue. Sure can't hurt.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
cummins2014
Utah
Posted: 09/09/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Same with the slide outs , make sure they are in before adding fluid. My fifth wheel although we are not talking slide outs came with just plain old hydraulic fluid, but some of the same fifth wheels had the ATF for the slide outs.
Edd505
Elephant Butte, NM
Posted: 09/09/19 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
It's called anti stiction fluid and I could not find a store that had it. They recommend a couple specific oils and they turned out to be racing fork oil, not a M/C shop had any of heard of them. I did find "slide oil" at an Holiday World RV.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
enblethen
Moses Lake, WA
Posted: 09/09/19 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
That should be "anti Friction"! Right?
BarneyS
S.E. Lower Michigan
Posted: 09/09/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Nope. Stiction is correct. It refers to the tendency of two materials that are at rest against each other to resist movement. Kind of like "sticking". [emoticon]
Anti stiction oil
Amazon.com results
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
