RV.Net Open Roads Forum: Fifth-Wheels: Hydraulic fluid for Lippert Ground Control
 > Hydraulic fluid for Lippert Ground Control
laknox
Arizona
Posted: 09/09/19 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Edd505 wrote:
laknox wrote:
Maybe this would be a good time to add some of the additive that LCI recommends, even if Campinfan isn't having the "popping" issue. Sure can't hurt.
Lyle
It's called anti stiction fluid and I could not find a store that had it. They recommend a couple specific oils and they turned out to be racing fork oil, not a M/C shop had any of heard of them. I did find "slide oil" at an Holiday World RV.
IIRC, one of the recommended products was from Caterpillar.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Edd505
Elephant Butte, NM
Posted: 09/10/19 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
laknox wrote:
Edd505 wrote:
Lyle
Lyle
Joys of living in the out back, not a large selection of stores to shop, especially when you need it now. Nearest Cats 2-3hrs North or South.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
laknox
Arizona
Posted: 09/10/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Edd505, there is a 2nd fluid besides the Cat-branded one. Just can't remember what it is.
Lyle
Cummins12V98
on the road
Posted: 09/11/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Bob's RV Repair in Moore's Hill, IN said the anti stiction fluid is BAD for the internal seals as it makes them soft and causes them to roll.
He is an expert at rebuilding the PIZZ poor hydraulic rams that Lippert supplies with quality components.
Use a QUALITY synthetic ATF! I use AMZ/OIL Signature Series Universal ATF.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
djousma
SW Michigan
Posted: 09/11/19 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Here is the link to the Lippert doc: https://support.lci1.com/documents/ti-19........anti-stiction-fluid-to-hydraulic-systems
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
Cummins12V98
on the road
Posted: 09/11/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Call and talk to the guy that actually fixes the POS rams that Lippert supplies. He will tell you NOT to use the fluid.
Campinfan
Washtenaw County, Michigan
Posted: 09/11/19 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. It is low with all slides in. I will have to hook it up to the truck to see what it looks like when all the jacks are retracted. I also thought about adding the stiction stuff even though I don't have popping.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Cummins12V98
on the road
Posted: 09/11/19 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
Add it at your own peril.
Edd505
Elephant Butte, NM
Posted: 09/14/19 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
LCI's recommended. The first two are M/C racers fork oil and none of the M/C shops had any.
1. Torco RFF Grade 15
2. Maxima Fork Oil Grade 15
3. Caterpillar Hydraulic Oil Additive 1U-9891
Edd505
Elephant Butte, NM
Posted: 09/14/19 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
If it's low you have a leak. Mine was one of the slide rams lost a seal and fluid was dripping out the coroplast.
