RV.Net Open Roads Forum: Class A Motorhomes: Towing
dodge guy
Bartlett IL
Posted: 09/10/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
gswcgi wrote:
If you get into an accident while towing that much over your weighted limit your insurance company will probably tell you to get lost !!
No they won’t. Same could be said if you were speeding and got into an accident.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Trumpet Player
Posted: 09/10/19 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Now that is a leap if I have ever seen one. Speeding compared to knowingly violating posted certification limits? I wouldn't be so sure about your answer if I were you. And you know this how?
2012 American Coach Revolution
tropical36
Southwest Florida_USA
Posted: 09/10/19 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Granted, they may tell you to get lost, if they even have a clue as to weight being a factor or for maybe not wanting to renew your policy next time, but they will have to pay, regardless.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
rk911
DuPage County
Posted: 09/10/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
civil suits can be filed by anyone for any reason anytime. but knowingly towing 1400-lbs overweight could be called an ambulance chaser's retirement plan. OP, you do what you want. the fact that you're even asking indicates you have doubts. good luck and be safe.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
tropical36
Posted: 09/10/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Again, where's the weak link and if we would have had an Allison 3000 tranny in our old P30, there wouldn't have been an overweight problem.
With checking out the specs on some of the newer Pace Arrow, 40ft DP's, the towing capacity is only 800lbs and all because of the Allison 2500 series tranny. Not that anyone, including the owners, pay it any mind and as long as it doesn't alarm and go into limp mode with overheating. I mean what kind of toad, weighs only 800lbs and assuming that one might be at max. GVWR, before hitching up?
tropical36
Posted: 09/10/19 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
tropical36 wrote:
Again, where's the weak link and if we would have had an Allison 3000 tranny in our old P30, there wouldn't have been an overweight problem and one that never created a safety problem in the first place.
ncrowley
Utah
Posted: 09/10/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
I do not think you should exceed the weight you are supposed to tow. So my advice is to not do it.
Nancy
Newmar Northern Star
PastorCharlie
NC
Posted: 09/10/19 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Larrysr1957 wrote:
My question is has anyone pulled a full size pickup with a 35 ft gas motor home I have a 1997 Fleetwood Bounder 34V with a Ford 460 engine and my tow limit is 3500 lbs my truck is 4900 lbs.
I towed a 4,900 lb. pickup with a 35 ft. MH with a 460 motor and 4 speed transmission for a few years and never once had any problem on flat land or mountain. I was under weight on the scales for the combination. Towing 4 down does not put any weight on the hitch only on the pulling and what if any on the stopping. If the auxiliary braking system is properly adjusted it will take all of the towed weight stress off the hitch and MH. Actually it can be set to actually pull back on the MH when stopping thus aiding the MH braking. The three potential stress situations are pulling, stopping and sharp turning. I used a 10,00 lb. Blue Ox hitch and a Brake Buddy brake system for the tow.
If you read the instructions on your hitch it is labeled for tongue weight. Such as you would have if towing a trailer. Not when towing 4 down.
I went to my local DMV with the titles for my current MH and tow and they assured me that as long as I was not over the rated weight for the motorhome and not over the 10,000 tow weight I was in compliance with the law. Your state may differ...my advice is to ask the Department of Motor Vehicles in your area...they will tell you Truth and give you the Facts.
way2roll
Wilmington NC
Posted: 09/11/19 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Not sure what any of this has to do with the OP who is admittedly 1400 lbs over. You say you were underweight on the scales and he admits he's over. Comparing oranges to basketballs.
* This post was edited 09/11/19 09:08am by way2roll *
dodge guy
Bartlett IL
Posted: 09/11/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
BTW. My MH is rated at 22k lbs (26k lb chassis). Forest River leaves 5k lbs for towing. But the MH has a CCC if 3500lbs. So I’m under the rated weight for a trip. Hat leaves me with the leftover weight for towing a bit more if I need too.
I have to look at the numbers again to give you actual numbers. But I figure I’m good for towing a 6k lb toad. Of course I would have to replace the hitch first.
