RV.Net Open Roads Forum: Travel Trailers: DIY project for Generator rack
 > DIY project for Generator rack
Snomas
Sedona, AZ
Posted: 09/08/19 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone made a rear rack for supporting a 110# generator & about 80# of misc items.
I'm thinking about an Aluminum 24"X 48" long rack attached to the back of my 22' trailer. Does the additional wt affect the tow set up and will I need to add some bumper supports. I see some solutions on the internet for about $200 but I would like to do it for less than that.
2018 F150 Lariat Crew Cab, 5.0 L V8, RWD.
2019 Flagstaff micro mini 21DS
Anderson WDH
K Mac
Lower Hudson Valley N.Y.
Posted: 09/08/19 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Man, I thought I was cheap$, lol. Most bumpers aren't very strong by themselves, the metal they use is usually a thin gauge. Try to attach to trailer frame and save some weight by letting your rack extend a little past your frame extension. Check your states regulations also as to weather you'll need lights, reflective D.O.T. tape, etc...
wanderingaimlessly
SOBOVA
Posted: 09/09/19 04:47am Link  |  Quote  |  Print  |  Notify Moderator
Dont forget that 200+ pounds off the tail end will affect tongue weight. You will likely end up light on the nose and have handling problems if you dont compensate.
valhalla360
No paticular place.
Posted: 09/09/19 04:52am Link  |  Quote  |  Print  |  Notify Moderator
Be careful of the weight distribution.
All in, your rack will likely run 250lbs and depending on the exact spacing, I would expect around 150-200lb reduction in hitch weight.
Given your's is a relatively small & light trailer, that could easily push you under 10-12% hitch weight...too light of pin weight can cause handling problems.
Please don't bolt such a heavy rack the rear bumper...it won't last long.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Jebby14
Windsor Ontario
Posted: 09/09/19 05:14am Link  |  Quote  |  Print  |  Notify Moderator
your rear bumper is likely little more than a pop can. remove it and integrate with the frame. also expect tongue weight issues and sway problems. can you put it on the nose?
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
stevemorris
ontario
Posted: 09/09/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
no way!!
the bumper isnt strong enough and 200 lbs plus on the rear is going to affect all kinds of stuff mostly related to tongue weight
put the generator inside the trailer or tow vehicle
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
eHoefler
ozark mountains
Posted: 09/09/19 06:00am Link  |  Quote  |  Print  |  Notify Moderator
All the weight that you add to the rear will remove about the same from the hitch, and add all of it to the axles
Example: 200 pounds on rear + 200 pounds removed from the hitch = 400 pounds added to axles.
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Snomas
Sedona, AZ
Posted: 09/09/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like I need to put the generator on the front rack where the battery goes. The generator alone would add about 110# to the tongue wt. How would that affect towing?
I don't want to have to move the generator in and out of the trailer or tow vehicle when on a trip for obvious reasons.
Lynnmor
Red Lion
Posted: 09/09/19 07:06am Link  |  Quote  |  Print  |  Notify Moderator
While the bumper is usually of "pop can" quality, the frame may not be much better. Some frames are pieced together and have little capacity to carry additional weight.
Snomas
Sedona, AZ
Posted: 09/09/19 07:07am Link  |  Quote  |  Print  |  Notify Moderator
stevemorris wrote:
no way!!
Inside the trailer or tow vehicle would be a last resort thing for me to do, because my DW needs a cooled down trailer when we make quick stops on trips to eat lunch, etc and I don't want to take the time to fool with a 110# generator.
