RV.Net Open Roads Forum: Travel Trailers: DIY project for Generator rack
 > DIY project for Generator rack
Snomas
Sedona, AZ
Posted: 09/10/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I like 12ga Angle for a 2'X4 'platform. It is light wt and strong enough for what I need to carry. A 2x2 x 1/8" steel angle across the bottom of the 4" bumper tube will also be strong enough and lighter than 1/4" angle. IMHO.
Note: My trailer is brand new. No rust yet!
What do you guys think!
2018 F150 Lariat Crew Cab, 5.0 L V8, RWD.
2019 Flagstaff micro mini 21DS
Anderson WDH
Lynnmor
Red Lion
Posted: 09/10/19 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Bert Ackerman wrote:
What is the criteria that determines that a manufactured beam is flimsy and somehow weaker than a rolled beam of the exact same dimensions? Why, because its welded together from 3 pieces of sheet? Personal opinion or did someone run the structural calculations.
I did my calculating while I was running weld beads over my four frame cracks.
Bert Ackerman
Palm Beach
Posted: 09/11/19 03:41am Link  |  Quote  |  Print  |  Notify Moderator
You had four frame cracks at the continuous machine welds where the flange was welded to the web of the main frame rail?
Lynnmor
Red Lion
Posted: 09/11/19 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Actually the cracks were where the cross members joined the flimsy web of the "I-beam". The flimsy flanges have little resistance to lateral movement and that flexing causes cracks at stress points.
Yes, welded I-beams could be made strong enough to do the job, but in the RV industry it is all about cheap and light weight, thus the use of this marginal product.
