RV.Net Open Roads Forum: Tech Issues: alternator
 > alternator
RLS7201
Posted: 09/09/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
MEXICOWANDERER wrote:
And the suffix for ANY of these bearings is 2RS meaning sealed both sides. The rear A6000 XX has a pair of Teflon bands on the outside. They fit better.
Some European alternators used a 6202 DRE bearing like the Bosch which is utterly stupid with a serpentine belt tensioner. Good bearings use a BLUE-GREEN polyurea grease like MOBIL 7.
OK I'm out of date on the front bearings but DD was also used by some manufactures for double seal bearings.
6203DD
6303DD
Richard
* This post was edited 09/09/19 05:10pm by RLS7201 *
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 09/09/19 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
ZZ is the only approved bearing for 19 years running and way beyond
I had a carton of USSR bearings that spun rough. Then there was Poland bearings which were trouble-free, then green seal SKF, and finally NTN.
Larry202br
Olathe, Ks
Posted: 09/10/19 05:18am Link  |  Quote  |  Print  |  Notify Moderator
ZZ is the only approved bearing for 19 years running and way beyond.
But you also say: "he suffix for metal shielded and not plastic sealed bearings is ZZ. ZZ bearings are definitely not suitable for alternators because of metal and graphite contamination."
Those statements seem contradictory. Can you clarify?
2006 Open Road 316 RLDS-5
2004 F-250 Diesel, short bed, SRW, Crew cab, 3.73 auto.
30sweeds
Iowa
Posted: 09/11/19 05:54am Link  |  Quote  |  Print  |  Notify Moderator
Victory Lap FDA-04 repair kit,20 bucks,has bearings,brushes.This started with an alarming belt squeak.Thought I had it figured out...3 times! First,AC clutch bearing,no help,idler and tensioner,still squeaking,new belt,nope.Really sounded like the alternator but looked pretty good when apart.I don't know.Will get it done today but don't have a lot of confidence.
MEXICOWANDERER
Posted: 09/11/19 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Yep you are absolutely correct I inversed numbers in a grand error.
ZZ is metal shielded and should NEVER be used
2RS has plastic seals and id the bearing of choice
DD has never been seen by me in over fifty years and tens of thousands of bearings/
I saw this earlier and meant to correct it. Looks like I am going back into the hospital today. Kidneys and adrenals.
MEXICOWANDERER
Posted: 09/11/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you have repeated failures using sealed ball bearings in a dirty environment here's the cure (not hypothesis -- this really works)
Smear a gob of grease onto both sides of the 2RS bearing then install. The gobs of grease act as a barrier and the effect is not subtle.
Rotobrator machine with steel shot for refinishing alternator cases and stripped starter housings.
Exposed bearings lasted 2 weeks in an LS brand rotobrator. Changed bearings gobbed on grease and they lasted 5+ years.
Delco CS-130 exposed rear 6000XX bearing. Common failures. Gobbed grease over exposed side, no more failures. Ever. This cure really works for all exposed bearings/
30sweeds
Iowa
Posted: 09/12/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Victory Lap FDA-04 alt repair kit,G3,has both bearings,20 bucks on Amazon.The problem started with an alarming belt squeak,thought I had it narrowed down....3 times!First was ac clutch bearing,no help.Next was idler and tensioner,no help.Replaced belt,nope.Installing alt bearings today but the old ones were good in my opinion.Hard to really pinpoint the noise with the stethoscope and the water and power steering pump is the only thing left.Any ideas?
 > alternator
