RV.Net Open Roads Forum: Tow Vehicles: Ram 2019 3500 diesel
Search only in Tow Vehicles
 > Ram 2019 3500 diesel
Page of 5
dennych1
Long Island New York
Posted: 09/09/19 07:36am Link  |  Quote  |  Print  |  Notify Moderator
I’m looking at this left over and asking people’s opinion . I’ve been a GM guy so not to fimiliar with ram
ib516
Canada
Posted: 09/09/19 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Currently, all the diesels by the big 3 (Ram, GM, Ford) are excellent. Can't really go wrong IMO. Pick the one you like.
One thing to note is that Ram has two versions of the 6.7L Cummins. A high output and a standard output. The high output comes with a heavier duty automatic transmission. Easy way to tell them apart (besides the window sticker), is the location of the transmission fluid dipstick.
If it's on the passenger side, it's the standard output Cummins and the Ram 68RFE trans. If it's on the driver's side, that's the HO engine and Aisin HD trans.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
dennych1
Posted: 09/09/19 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Which is the lower power do they call that type 6 transmission. That’s what a friend has
Bionic Man
Colorado
Posted: 09/09/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Both engines are good. Both transmissions are good. The Aisin is better.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Cummins12V98
on the road
Posted: 09/09/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Not sure how a 19 can be a leftover???
AISIN nets the most HP and the 68RFE has less. Both are good but the AISIN is a True Medium Duty Trans!
This is what you should be looking for.
CUMMINS, AISIN, 3500, LongBed (SRW or DRW), 5er tow prep, Factory Rear Air, pick your trim level. Once behind the wheel the smile never goes away!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rhagfo
Portland, OR
Posted: 09/09/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Well I got three of of the four, DRW and leaf springs not air, Laramie trim level.
2019 could be a short model year for Ram, 2020’s looking to come out.
OP, is it SRW or DRW and what trim?
ShinerBock
SATX
Posted: 09/09/19 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
If you had an Duramax with an Allison, then you might be disappointed going to the Aisin or 68RFE. The Aisin is a slow shifting and clunky trans, and the shift logic is not as good as the Allison. However, it is a more stout trans with a PTO. The 68RFE shifts quicker and much smoother than the AIsin, but still not as good as the Allison in its shift logic. The most that can be towed with the 68RFE is 22k.
The other major difference between the two is compression ratio of the engine each comes with which will effect fuel economy. The Cummins with the Aisin has a lower 16.2: compression ratio which is needed to attain higher 400 hp and remain emissions compliant, but will have less fuel mileage in comparison. The Cummins with the 68RFE has a compression ratio of 19.0:1 and makes 370 hp, but will have better fuel economy. It just depends on which is more important to you.
ib516
Canada
Posted: 09/09/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Aisin AS69RC comes with the HO engine. 385hp, 930tq
Ram 68RFE comes with the standard engine. 370hp, 800tq
IN 2020, the HO is 400hp, 1000tq, Standard output is 370hp, 850tq.
Cummins12V98
on the road
Posted: 09/09/19 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
I will forgive you. [emoticon]
Cummins12V98
on the road
Posted: 09/09/19 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
The 19 DRW I test drove had the 400/1000 rating.
Page of 5
