RV.Net Open Roads Forum: Pulling a TT that is pulling a Boat Trailer
 > Pulling a TT that is pulling a Boat Trailer
Bumpyroad
Virginia
Posted: 09/09/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
matthewijenkins wrote:
From what little research I've done, it seems like it's only legal to tow two trailers if i have a fifth wheel.
Isn't that triple towing and a no no in GA
bumpy
2oldman
Ca
Posted: 09/09/19 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
TK would be a Truck Kamper. It's double towing.
* This post was last edited 09/09/19 05:20pm by 2oldman *   View edit history
wanderingaimlessly
SOBOVA
For what you want to do, take a camper and a trailered boat in Ga, either a Motorhome pulling your boat trailer, or, a truck with a slide in camper with the trailer behind.
WNYBob
Tonawanda, NY
Posted: 09/09/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Not legal in New York state!
Mickeyfan0805
SE Wisconsin
Posted: 09/09/19 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Hondavalk wrote:
MH-Motor Home
TK- Truck camper
Yep - sorry, typo. I fixed it.
cavie
Posted: 09/09/19 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Not legal in Florida.
samsontdog
Oregon, Wash Coast summer, Yuma Az winter
Posted: 09/09/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Legal in Calif towing a TT or a 5th w as long as you have the proper qualifications
samsontdog">">
midnightsadie
ohio
Posted: 09/09/19 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
DO NOT rely on the thin bumper on the back of your tt. have a real hitch installed.
Jebby14
Windsor Ontario
Posted: 09/10/19 03:40am Link  |  Quote  |  Print  |  Notify Moderator
boats are cheap and readily available around here. switch to an 3 bench aluminum. my 14 footer can easily be lugged around by 2 and there are many options lighter. or get a truck camper and tow as normal if you can afford enough truck.
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
valhalla360
No paticular place.
Posted: 09/10/19 05:52am Link  |  Quote  |  Print  |  Notify Moderator
In addition to the legal aspects, what is the hitch weight of the boat trailer (fully loaded).
One of the reasons 5th wheels are allowed is 5th wheels normally start at 20-25% of the trailer weight on the hitch and the spacing of the 5th wheel axles, means only around 50% of the 2nd trailer hitch weight comes off the pin weight...therefore it's usually not an issue.
On the other hand, bumper pull trailers usually run 12-15% on the hitch and due to wheel spacing, closer to 80% of the 2nd trailer hitch weight comes off the pin weight...this makes it far more likely that the hitch weight on the main trailer is too light and it gets squirly when towing.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
