RV.Net Open Roads Forum: Class C Motorhomes: Shower stall caulking.
 > Shower stall caulking.
klutchdust
Orange, California
Posted: 09/09/19 11:49am Link  |  Quote  |  Print  |  Notify Moderator
In my Cambria I see there is caulking where the side walls and floor pan meet.
The walls fit over the pan. The caulking is discolored and coming off, is it necessary for it to be there.
Not the original owner, second owner.
Hondavalk
Toledo
Posted: 09/09/19 11:58am Link  |  Quote  |  Print  |  Notify Moderator
While water should not get over the pan lip, the caulk keeps water from sitting between the inside of the wall panel and the lip of the pan. That would not be accessible to clean and mold could form.
MDKMDK
Canada
Posted: 09/09/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
As long as the walls overlap the pan on the interior side of the pan, it's probably not necessary, except in the even of an overflow in the shower pan itself, but that would be another issue entirely. That caulking would then be the least of your worries.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
VA-Apraisr
glen allen, VA
Posted: 09/09/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
"An ounce of caulk is worth a pound of cure"....well, in my book anyway. Probably not necessary but I re-caulk this seam about every 2-3 years just to be safe. Cheaper than having to remove shower for moisture/mold issue. I use Duralink 50 which stays 50% flexible for life (useful for RV that's constant vibrating/moving). I use this stuff for windows/vents/shower/exterior lights etc. and have had very good results.
SailingOn
Central Texas
Posted: 09/09/19 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have read, some years ago, that this joint, between the shower pan and the walls, should not be caulked, because caulking this junction will close off the space behind the shower enclosure so it cannot breathe, and moisture will then allow mold.
Considering how loosely my rig is put together, this seems unlikely.
Mine came from the factory caulked.
Buck: 2004 Wilderness Yukon 8275S, now memories.
Star: Open range LF297RLS. 2 air conditioners!
Togo: 2014 Winnebago View Profile, 2013 Sprinter chassis; 16 mpg
AJ: 2010 F150 ExtCab, 2WD, 6.5' bed, 5.4L V8, 6A, Max Tow: 2030# payload.
AD5GR
MURPHY55347
Savage, MINNESOTA
Posted: 09/09/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
More than likely Winnebago used a Silicone caulk for this. You will never get new stuff to stick without removing all of the old stuff. And I mean ever trace. Probably more work than it is worth.
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 09/11/19 05:14am Link  |  Quote  |  Print  |  Notify Moderator
The shower pan should have a 2" lip behind the walls, and I agree with previous comments -- this gap shouldn't be caulked. When I installed a similar style shower at our home, the instructions were pretty clear about leaving that gap between the pan and the wall panels open. Depending on outside temps, you might wind up with condensation which will run down the back of the wall panels, and that needs a way to escape. Caulking would trap it.
  • 2005 Winnebago "Minnie" 31C (was a three-time Jayco owner)
  • 2012 MasterTow Dolly pulling a 2003 Jeep Liberty (had Ram 2500 CTD, Dodge Durango, Honda Odyssey...)
  • Onan Microquiet 4000, plus 130W solar and Honda EU2000i twins for backup
