RV.Net Open Roads Forum: Fifth-Wheels: Winterize or Not
 > Winterize or Not
Campinghoss@51
Windsor NC
Posted: 09/10/19 04:25am Link  |  Quote  |  Print  |  Notify Moderator
The weather can change overnight. Since you are closer to the mountains than I am I would definitely winterize. Running the rv antifreeze is not costly nor difficult but replacing plumbing is a hassle. While looking at the average temp or historical temps is a good start it still does not count for the extreme changes NC can see. I keep my fiver under a shelter and it is a four season. I run antifreeze thru mine each year.
Just my two cents.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
rsgs
Harrison Twp., Michigan
Posted: 09/10/19 05:16am Link  |  Quote  |  Print  |  Notify Moderator
I never listen to the weather report when fall comes around. I have two fifth wheels in different locations. At the first of September, I blow out lines, drain the hot water tank, and add red pop to the traps. This way I know if something unforeseen comes up and I don't get back to either one for a month or two, it's taken care of and I don't have to worry. It's ALWAYS better to be safe than sorry and it only takes a few minutes.
John and Robyn
Penny (Brittany)
·2009 Chevy Silverado 2500HD 4x4 Crew LB Duramax/Allison
·2004 Fleetwood/Prowler Regal Extreme Edition 2952 Bunk
-2005 Forest River 28RK
Mickeyfan0805
SE Wisconsin
Posted: 09/10/19 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Do you have quick and ready access to the rig? If you can get out in the case of a surprise cold snap, then you could wait and watch. If there is any chance you might not be able to get to it during the winter, however, I wouldn't risk it! THe relatively small investment of time and money is a cheap insurance policy.
Cummins12V98
on the road
Posted: 09/10/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
sayoung wrote:
gbopp wrote:
Just blow out your water lines and pour some pink stuff in the traps.
It's quick and simple. Then you don't have to be concerned with dropping temps and can do it after every trip during colder weather.
I will add open the faucets while blowing out & drain the water heater also. I open the low points, blow out, drain water heater , anti freeze in traps. But, I keep my heat on about 50 and it very seldom gets into the teens here.
Completely agree!
I didn't think about the "P" traps first time!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dave H M
IL
Posted: 09/14/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
so if you don't winterize and get caught with your pants down, who is to blame? [emoticon]
teegee1025
New York
Posted: 09/17/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all. We will winterize at the end of October. Now....our storage place up in Syracuse used to do this for us. Hoping it is an easy process. Google here I come!!! [emoticon]
sayoung
Tx
Posted: 09/17/19 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
I get tickled on all the rv forums I visit talking winterizing cause it's gonna be 97 here today . Also get a good laugh over on the Kubota tractor board, all the northern folks hooking up the snow blowers. Not makeing fun because I have been in the cold climates a few times it's just funny to me how early you must prepare. We don't even give an early morning frost a thought until usually mid November.
Mickeyfan0805
SE Wisconsin
Posted: 09/17/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
The ease often depends on the rig, but it's not hard at all. Takes me 20 minutes and 4 gallons of antifreeze.
Dave H M
IL
Posted: 09/18/19 06:31am Link  |  Quote  |  Print  |  Notify Moderator
holy moley Mickey, mine takes 2 gal. [emoticon]
Mickeyfan0805
SE Wisconsin
Posted: 09/18/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
My lines take about a gallon and a half. Another gallon+ fills the p-traps. The final gallon is dumped into the black tank so that it doesn't sit dry for the 7-8 months our rig is not in use.
 > Winterize or Not
