RV.Net Open Roads Forum: Tech Issues: Black Water Tank Missing Capacity
 > Black Water Tank Missing Capacity
Lantley
Ellicott City, Maryland
Posted: 09/11/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
How much residual water remains in the tank? The tank does not drain to a bone dry status. THere is always some water left.
Where is the output pipe in relation to the tank? I doubt it is located in the very bottom of the tank.
Most likely it's attached to the side of the tank a couple of inches from the bottom. Hence the tank never drains completely and always contains some water.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
Bert Ackerman
Palm Beach
Posted: 09/11/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
? My black and gray tanks always seem to drain to bone dry status taking into account the bottoms are sloped, and the nipple is formed into the tank so it's invert is even with the tank bottom. I can see a fresh tank holding residual water, but if it's the typical black or gray tank then something else is going on for it to hold enough water to affect overall capacity, like a big loogie jammed into the outlet or something.
