RV.Net Open Roads Forum: Tech Issues: DIY-who's tackled Foggy Glass repair?
 > DIY-who's tackled Foggy Glass repair?
RLS7201
Posted: 09/22/19 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
repair kit,
Desiccant foam spacers from Amazon
I use 3M Window Weld for the sealer.
Richard
* This post was last edited 09/22/19 03:02pm by RLS7201 *   View edit history
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
BarneyS
S.E. Lower Michigan
Posted: 09/22/19 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
Chum lee
Albuquerque, NM
Posted: 09/22/19 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
The problem with multi-pane windows whether they have inert gas inside them, or just dry air (like from a scuba tank) is that there can not be ANY WAY for moisture (humidity in the air) to find its way through the hermetic seals and get between the panes. If/When it does, when the temperature drops below the dew point, the moisture WILL condense inside the windows and you will be back to square one. If you are located in a hot very dry area, the moisture may evaporate to the exterior of the frame, but, it will eventually return as/if the relative humidity goes up. Once the inside of the glass gets water spotted or etched, . . . . . you're done.
Chum lee
