RV.Net Open Roads Forum: Tech Issues: 6 Volt RV batteries
 > 6 Volt RV batteries
Page of 6
Willcamp4
Nevada
Posted: 09/09/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have been a fan of Trojan batteries for many years. I have a 2005 Alpenlite and use a bank of four batteries. When the trailer was new I installed a set of T-105s that lasted about 7 years, and I installed a new set. It seems to be time to replace them again as they won't stay charged above about 12.1 volts. The only issue I have is that the Trojans have gotten SO EXPENSIVE. What I'm wondering is whether there is another brand/battery that is reasonably priced and dependable.
Willcamp4
2012 Ford F-250 Super Duty, Crew Cab, Lariat, 6.7L PSTD, Air Lift rear suspension.
Alpenlite Valhalla Limited Fifth Wheel, two Solar panels, four six-volt batteries, two Honda EU2000i generators
enblethen
Moses Lake, WA
Posted: 09/09/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
I get 6 volters from Costco. About $80 per battery.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BFL13
Victoria, BC
Posted: 09/09/19 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
"...and I installed a new set. It seems to be time to replace them again as they won't stay charged above about 12.1 volts"
An amazing statement! If they took a long time to get that bad, and you kept using them till now, then it would seem you might only need one 12v battery to get the job done. Why buy four new 6s if you only actually need one 12v batt?
This is all very peculiar!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Diaz Lake Campground, California
Posted: 09/09/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Trojans worked great for seven years and you want a different brand to “save” a few upfront bucks?
philh
Belleville MI
Posted: 09/09/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
what brand convertor/charger?
twodownzero
NM
Posted: 09/09/19 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Sams club is your friend.
beemerphile1
Ohio
Posted: 09/09/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I get my GC2 (6v golf car) batteries at Sam's Club. I plan (usually get) a minimum of 7 years use.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
IAMICHABOD
Sunny So Cal 90713
Posted: 09/09/19 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Costco would be my choice,6 years and still holding charge and they get a lot of use.
I checked Sams and Costco they both had them at about the same price the ones at my Costco were newer,only 2 months old and Sams were 6 months or more old some were 9 months old.I think in my area Costco sells more and quicker so they turn over faster.
I would check around.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
bpounds
Sophmore Brain...
Posted: 09/09/19 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Please explain. It would seem you are saying that long battery life means he has more battery capacity than he needs. Or perhaps you meant that he survived on weak batteries for a while, and that this means he has more battery than needed. Neither makes much sense.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Willcamp4
Nevada
Posted: 09/09/19 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
In answer to the ingrained question...I survived on weak batteries for a long time, most of this season. I was getting by. Thanks for the suggestions. I also found I can get more of the Trojans through golf cart repair companies for alot less money, if I choose to do that.
Page of 6
