Willcamp4
Nevada
I have been a fan of Trojan batteries for many years. I have a 2005 Alpenlite and use a bank of four batteries. When the trailer was new I installed a set of T-105s that lasted about 7 years, and I installed a new set. It seems to be time to replace them again as they won't stay charged above about 12.1 volts. The only issue I have is that the Trojans have gotten SO EXPENSIVE. What I'm wondering is whether there is another brand/battery that is reasonably priced and dependable.
Willcamp4
2012 Ford F-250 Super Duty, Crew Cab, Lariat, 6.7L PSTD, Air Lift rear suspension.
Alpenlite Valhalla Limited Fifth Wheel, two Solar panels, four six-volt batteries, two Honda EU2000i generators
enblethen
Moses Lake, WA
I get 6 volters from Costco. About $80 per battery.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BFL13
Victoria, BC
"...and I installed a new set. It seems to be time to replace them again as they won't stay charged above about 12.1 volts"
An amazing statement! If they took a long time to get that bad, and you kept using them till now, then it would seem you might only need one 12v battery to get the job done. Why buy four new 6s if you only actually need one 12v batt?
This is all very peculiar!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Near Bishop, California
Trojans worked great for seven years and you want a different brand to “save” a few upfront bucks?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
philh
Belleville MI
what brand convertor/charger?
twodownzero
NM
Sams club is your friend.
beemerphile1
Ohio
I get my GC2 (6v golf car) batteries at Sam's Club. I plan (usually get) a minimum of 7 years use.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
IAMICHABOD
Sunny So Cal
Costco would be my choice,6 years and still holding charge and they get a lot of use.
I checked Sams and Costco they both had them at about the same price the ones at my Costco were newer,only 2 months old and Sams were 6 months or more old some were 9 months old.I think in my area Costco sells more and quicker so they turn over faster.
I would check around.
Former El Monte RV Rental
Buying A Rental Class C
bpounds
Sophmore Brain...
BFL13 wrote: "...and I installed a new set. It seems to be time to replace them again as they won't stay charged above about 12.1 volts"
Please explain. It would seem you are saying that long battery life means he has more battery capacity than he needs. Or perhaps you meant that he survived on weak batteries for a while, and that this means he has more battery than needed. Neither makes much sense.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Willcamp4
Nevada
In answer to the ingrained question...I survived on weak batteries for a long time, most of this season. I was getting by. Thanks for the suggestions. I also found I can get more of the Trojans through golf cart repair companies for alot less money, if I choose to do that.
