RV.Net Open Roads Forum: Travel Trailers: Pulling with 1/2 ton
 > Pulling with 1/2 ton
Page of 6
MitchF150
Puyallup, WA
Posted: 09/10/19 12:10am Link  |  Quote  |  Print  |  Notify Moderator
I'm towing this with my F150. It's #7000 GVWR and has a dry weight figure too, but it's not dry anymore and I figure it weighs every bit of it's GVWR the way I load it for travel.. It's a Rockwood 2511 "Mini Lite" (ha, ha) it ain't "Lite" at all!
I do fine with it, but would not want to go any heavier..
Do all the math you want, but in the end, it's how you load it and what it weighs after all you load or do not load in it.
Good luck!
Mitch
stevemorris
ontario
Posted: 09/10/19 04:33am Link  |  Quote  |  Print  |  Notify Moderator
our trailer has a gross weight of 7000, we tow with a 4door ram 1500 hemi 8 spd 4wd.
we dont travel light but there's just two of us
no issues towing, but i wouldnt go any bigger.
like most of us, wind is the enemy as well as weight
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
tls5150
Posted: 09/10/19 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the responses!! My 1/2 ton is rated to pull 9,400. Was considering the new 1/2 Silverado with max tow package rated at 11,300. It is just DW and I nothing unusual as far as packing except two bicycles just struggling on what to do
Tim & Debra Smith
2018 Chevy Silverado 2500 LT Texas edition
2020 Rockwood 2612 ws ultralite
troubledwaters
Potomac
Posted: 09/10/19 05:18am Link  |  Quote  |  Print  |  Notify Moderator
You can figure this out based upon the Truck "you" have, the trailer "you" have, and the way "you" will load them by looking at the information published Here. I figure real life is better then speculation.
jamesu
Camano Island, WA
Posted: 09/10/19 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I am confused: the TV listed in your signature is a 3/4 ton (“2500”) Silverado same as mine, except mine is a Duramax diesel. Is your signature TV # a typo, or are you just thinking of downgrading to a 1/2 ton? After towing with a 1/2 ton all those years, and now with having the benefit and luxury of more power than I actually need, I would never go back.
2011 Chevy 2500 Duramax diesel
2019 Timber Ridge 24RLS (Outdoors RV)
Go Cougs!
valhalla360
No paticular place.
Posted: 09/10/19 06:06am Link  |  Quote  |  Print  |  Notify Moderator
People usually have no clue how much "nothing unusual" weighs.
It you don't want to obsess over it, I would start assuming GVWR as a starting point.
Yes, 1/2 ton trucks can tow a fair bit but regardless of what the "tow rating" is, you also have to look at payload limits.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
APT
SE Michigan
Posted: 09/10/19 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Should be fine. Those trucks tend to have 1700+ pounds of payload. 7500 pounds loaded, 950-1000 pounds TW. Get a good WDH with integrated sway control. Enjoy.
2017 Subaru Outback 3.6R
Desert Captain
Tucson
Posted: 09/10/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
I have yet to encounter any half ton truck that could actually tow at its rated maximum. The problem will be that you run out of payload long before you even get close to your max tow rating. Saw a Dodge Ram 1500 4 X 4 crew cab the other day that had 977# of payload... my Honda Ridgeline haas 1,577, go figure. [emoticon]
My SCab F-150 was rated for 8,600 max tow but my 5,600# 22' TT was alll that it could handle - it towed well but I was near or even at my max payload almost every trip.
[emoticon]
noteven
Turtle Island
Posted: 09/10/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Tweeeeet! OP! 2 minutes for signature vehicle doesn’t match the question vehicle! Let’s go...
Bobbo
Wherever I park
Posted: 09/10/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Yes. But when trying to determine how much "what it weighs" you can handle, or how much truck you need to buy, the math is your only gauge. Unless you trust the salesman when he says "sure, you can tow that with this truck."
Bobbo and Lin
Page of 6
