RV.Net Open Roads Forum: Travel Trailers: Pulling with 1/2 ton
 > Pulling with 1/2 ton
Page of 6
TurnThePage
North ID
Posted: 09/11/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
TurnThePage wrote:
In reference specifically to half ton towing, why do people say, "use the max trailer weight?"
Some trailers have 3000 lbs of cargo capacity (Who's going to use all that?!). Some have under a 1000.
Even with excessive amounts of tools, backup parts, winter supplies, summer supplies, extra battery, solar panels, various added accessories, food, 50 gallons of water, grill, camp stove, camp table, camp chairs, cast iron pots and pans, and assorted other sundries, I can't seem to get over about 1500 lbs of stuff in my trailer.
What is your trailer dry weight, actual weight and GVWR?
What is your towing capacity?
I'll have to be approximate.
Dry weight: 4800 lbs
Actual weight: 6100 last time weighed, as high as 6500 lbs
Trlr GVWR: 6000 lbs
Ram half ton towing capacity: 10,600 lbs
2015 Ram 1500
2004 Pioneer 18T6
time2roll
Posted: 09/11/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Trlr GVWR: 6000 lbs
So you are fine and it does show how easy it is to go over the trailer GVWR.
Even if you used GVWR and went with a 10,600 GVWR trailer with 3,000 carry capacity but used only 1,500 would put you at 9,100 real towing weight and is probably a bit much. This tells me you will not be stuck with an undersize trailer for using the GVWR.
That is the method to my madness using GVWR instead of dry weight.
And of course the alternative is to consider a 9,600 dry weight trailer when you think you will only carry 1,000 pounds of junk. Then you find out the delivered weight is over 10,000 and your junk is 2,000..... and then you looking for a diesel dually.
* This post was edited 09/11/19 01:38pm by time2roll *
675w Solar pictures back up
TurnThePage
North ID
Posted: 09/11/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
As already found by another poster, there are trailers out there that are fairly light weight, yet have a huge payload capacity. If a trailer suits your needs without going near that max, why rule it out?
We gotta be real too. I would have to exceed the tow vehicle payload by a fair amount to tow a 10000 lb travel trailer. 7500 - 8000 is a reasonable maximum weight range for the average half ton.
Argh! You edited while I was responding!! [emoticon]
LoudRam
Southern NJ
Posted: 09/11/19 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you to those who pointed out that using the GVWR to buy a trailer isn't always necessary. You just have to know how to figure out all your weights. In my case my trailer has a dry weight of 6628lbs. We might have 500lbs to 600lbs of stuff bringing my total weight into the 7200 to 7300 pound range. Yet my CCC is 3012lbs. As stated earlier and often on this board, you'll run out of payload before hitting your max tow. That's the number to watch.
Todd
Desert Storm Vet (US Navy)
2019 1500 Classic Quad Cab Express 4X4 5.7 Hemi 3.92
2018 Dutchmen Aspen Trail 2880RKS
If you can read this thank a teacher
If you can read this in english thank a vet
Desert Captain
Tucson
Posted: 09/11/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
am1958 wrote:
Desert Captain wrote:
So what is "odd"? [emoticon]
We both had rigs that towed well at or near our payload limits. What was your alleged towing capacity? I'm guessing Ford told you it was 9K# or more but we both know better.
[emoticon]
What is odd is that you say 6500lb "is all it could handle" which, to me, implies that anything more and the rig becomes unwieldy or unable to pull efficiently yet I'm pulling 1000lb more than that and find it all very manageable. Not saying you are wrong or anything just observing that our separate experiences are so disparate.
I can't even remember what the tow rating is but I know it was way more than I'd ever want or need.
What I said was my F150 was at its payload limits with a 5,600# TT. With about 750# of tongue weight and the hitch more than half of the payload (1,426#) was gone before I
loaded anything. Add the 225# for the Leer shell and I was almost out of payload.
I would bet that the tow capacity you have forgotten is far higher than any number you can actually tow without compromising max payload.
Mickeyfan0805
SE Wisconsin
Posted: 09/11/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
This isn't the universal truism that it once was, at least by the numbers. There are many F150 configurations with payloads well above 2,000 pounds. A 2,200 pound payload, with just a couple and some gear, would still leave room for 1,500+ pounds of tongue weight (the RAWR is a secondary question that's harder to estimate in generic terms). That's a lot of trailer.
fdwt994
Indianapolis, IN
Posted: 09/12/19 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Do you want opinion or fact? No offense, but too many come here seeking the validation they want when they know they probably aren't supposed to tow the camper they have (or want) with the truck they have. Educate yourself using a resource like this and you'll have the facts, not opinions and anecdotal evidence. These numbers are derived by Engineers who do this stuff for a living. Remember, it's not only about what you can pull. It's what you can control and stop also. Good luck
2018 F250 6.2 Crew Cab
2018 Salem Hemisphere GLX 312QBUD
A family who loves to camp!
trailer_newbe
Tucson
Posted: 09/12/19 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Watch this—> Https://youtu.be/M75Sm7XaIdY
2018 Jayco White Hawk 28RL
JIMNLIN
Oklahoma
Posted: 09/13/19 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Most you tubes, like the clicky, I've seen are from new folks to the trailering world or maybe owned a couple of RVs and tried towing it with a 10 years old and older std duty 1/2 ton truck like my wifes previous '06 1500 chevy 4l60e and a low power 5.3....or like I see in some folks sig with a F150 with a tow package... any engine with a 6800-7050 gvwr and tiny 3800 rawr. These trucks aren't the best selections for towing even their rated tow ratings.
These type folks in you tubes seem to lump all 1/2 ton trucks in the same mold because their trucks they chose didn't do well towing a certain size trailer.
One half ton truck have more different GVWR and RAWR than any truck on the road. So when someone jumps up and says a 1/2 ton truck should stick with a 6k trailer I say bull dust. Need to stop watching you tubes/reading magazine specs and read the truck makers body builders weight specs and tow ratings on their respective websites for actual numbers specific to their model trucks options and std equipment.
Over the years 1/2 ton trucks have had GVWRs up to 8600 lbs and 6000 rawr numbers. These truck sit mostly on 3/4 and one ton SRW frames. Lots of '00-'06 1500HD GM trucks 8600 gvwr and 6000 rawr 6.0 engines 4l80 trannies out here doing its rated job of pulling 10k TT or 5th wheel trailers. Now days its GMs NHT package with the 6.2 engine at 420hp/460 torque 7600 gvwr and 4300 rawr that get the bigger numbers.
Same with Fords F150 with GVWRs from 6200 lbs up to 8200 lbs smaller 4800 rawr on down to 3200 lb rawr. Nite and day differences.
Many F150 owners bit into the "max tow" option which has nothing to do with getting a F150 with the max payload or the maximum tow ratings.
Or they bit into the 2800-3200 lb gvwr based payload debacle. Choose the right F150 gvwr/rawr packages for towing those 10k trailers.
librty02
Western Pa
Posted: 09/13/19 07:02am Link  |  Quote  |  Print  |  Notify Moderator
I seen that video when it first came out and it is completely based on opinion and not facts whatsoever. I even commented in his video about it and he completely blew me off because he knows that it's the truth. There are soooo many different versions of a half ton truck today that his blanket statement is completely false.
* This post was edited 09/13/19 07:13am by librty02 *
2011 FORD F-150 FX4 CREW CAB ECO...
2018 Ford F-150 Max Tow Crew 6.5 3.5 Eco...
2013 Keystone Passport 2650BH, EQUAL-I-ZER 1K/10K
Page of 6
