RV.Net Open Roads Forum: Travel Trailers: Pulling with 1/2 ton
 > Pulling with 1/2 ton
Page of 6
martinto
South Carolina
Posted: 09/10/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
martinto wrote:
tls5150 wrote:
Thank you all for the responses!! My 1/2 ton is rated to pull 9,400. Was considering the new 1/2 Silverado with max tow package rated at 11,300. It is just DW and I nothing unusual as far as packing except two bicycles just struggling on what to do
GMC Sierra 1/2 ton 6.2L with Max Tow Pkg. 28 ft. TT loaded for a cross country trip out west...weighed in 7000 Lbs +/-. No problem pulling or braking. If truck is maintained to near spec level and you know it’s limitations, the set up and pulling of a properly loaded rig will allow you to travel safely.
It’s just me and my wife, and two small dogs. BTW...looked for my truck for over 6 months...found a 2016 Texas Edition Sierra in Charlotte NC, 90 miles north of our house. Crazy thing, we retired to S.C. from Houston, TX,, and end up with a Texas Edition Sierra located in NC. I guess it was meant to be!
am1958
SE Michigan
Posted: 09/11/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Desert Captain wrote:
So what is "odd"? [emoticon]
We both had rigs that towed well at or near our payload limits. What was your alleged towing capacity? I'm guessing Ford told you it was 9K# or more but we both know better.
[emoticon]
What is odd is that you say 6500lb "is all it could handle" which, to me, implies that anything more and the rig becomes unwieldy or unable to pull efficiently yet I'm pulling 1000lb more than that and find it all very manageable. Not saying you are wrong or anything just observing that our separate experiences are so disparate.
I can't even remember what the tow rating is but I know it was way more than I'd ever want or need.
Vintage465
Prunedale CA.
Posted: 09/11/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
As you can see the answers are all over the radar. For the most part everyone likes what they tow with. I've towed with 3/4 tons, 1 tons, 1/2 tons.....all the same 7000 pound trailer. All of them towed fine. Actually the 1/2 ton was '99 Suburban 4x4 with 5.7 and a tow package and it towed the best overall compared to the other rigs. Likely cause it had the best power. It was real stable, though not as stable as the 1 ton. That 1 ton thing towed like a train with a car on rails. And as mentioned, wind is the big enemy to 1/2 ton rigs. And I don't mean a cross wind, I don't think there should ever be an issue with cross wind if your lash up, suspension and tires are correct. I mean a head wind. I tow with a diesel and a head wind means nothing to me. Doesn't slow the truck a bit or make the engine louder. It just uses more fuel. With the gas engine'd rigs I had, head winds were maddening
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retiring in 2021, then look-out road, here we come!
mnaquaman
Farmington, MN
Posted: 09/11/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
For what it is worth here are my thought!
Getting others feedback on their experiences never hurts. Then again ignore the ones that simply say 3:42 gears are not enough, I wont pull anything with out a diesel and lastly the guy that can pull anything with his Honda!
Like others have commented - use the max trailer weight not the dry weight.
I run a 1/2 ton Chevy Silverado, 3:42 gears, 5.3L, and all of the towing options pulling a Jayco 23BHM that has a max weight of 6250lbs.
I try not to exceed 75% of the vehicle tow capacity.
Why 3:42 gears - there are in the middle, not stump pullers and not mileage gears! I can pull the mountains - I might not be able to blast up them at 65MPH but I can get up them!
I have towed at max capacity and for me it was not a comfortable experience.
Find a capacity calculator on-line. Run your own numbers and make up your own choices.
I found a calculator that calculated all of the capacities based on your particular circumstances. It told me that how many lbs I was under or over the manufactures weight limits.
Happy Camping 7 Safe travels!
Randy & Sharon Engelland
Farmington, MN
2017 Jayco 23bhm
2015 Chevy Silverado LTZ
TurnThePage
North ID
Posted: 09/11/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
In reference specifically to half ton towing, why do people say, "use the max trailer weight?"
Some trailers have 3000 lbs of cargo capacity (Who's going to use all that?!). Some have under a 1000.
Even with excessive amounts of tools, backup parts, winter supplies, summer supplies, extra battery, solar panels, various added accessories, food, 50 gallons of water, grill, camp stove, camp table, camp chairs, cast iron pots and pans, and assorted other sundries, I can't seem to get over about 1500 lbs of stuff in my trailer.
2015 Ram 1500
2004 Pioneer 18T6
gmckenzie
BC
Posted: 09/11/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I don't think you will find a trailer that can be towed by a 1/2 ton with 3K carrying capacity. 1500 seems more the norm (and I've been looking at this lately).
2015 GMC Sierra 4x4 CC SB Max Trailer
2010 Cougar 30RKS
gmckenzie
BC
Posted: 09/11/19 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Just on the 3.42.
My 1500 with the max trailering has a 6 sp and 3.73 gears. Newer versions have a 10 spd and 3.42 gears. The newer truck have an overall higher numerical final drive in 1st gear due to a better 1st on the 10 spd vs the older 6 spd.
I think it changed in 2017 (mine is 2015).
time2roll
Posted: 09/11/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
What is your trailer dry weight, actual weight and GVWR?
What is your towing capacity?
675w Solar pictures back up
Mickeyfan0805
SE Wisconsin
Posted: 09/11/19 11:53am Link  |  Quote  |  Print  |  Notify Moderator
I've made this argument a number of times. The best example I can find in the few minutes I have to look right now is from the Keystone Passport line. The 239MLWE is a 25'5" trailer with a dry weight of 4,402 and a carrying capacity of 998. The 2210RBWE is a 26'3" trailer with a 4,796 and a carrying capacity of 2,704. The two trailers are very similar off the lot (save a couple inches and 394 pounds), but the first has a GVWR of 5,400 while the latter has a GVWR of 7,500.
In either case, most people are going to load them the same. Thus, for example, let's say they load 1,500 pounds of propane, liquids, extras, gear and food. The person that buys the 239MLWE would have a trailer that weighs 5,902 pounds and is 502 pound OVERloaded. The person who bought the 2210RBWE, on the other hand, would have a trailer that weighs 6,296 and is still more than 1,200 pounds UNDERloaded.
In this instance, if the person was comfortable with up to 6,500 pounds loaded, they would have bought the 239MLWE based on the 'buy based on GVWR' advice but, in fact, would have had a much safer set-up with the 2210RBWE.
gmckenzie
BC
Posted: 09/11/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
And I just found one, so ppbbbtttt!!!! to me.
Page of 6
