RV.Net Open Roads Forum: Tech Issues: Radiator performance? Life expectancy?
 > Radiator performance? Life expectancy?
RLS7201
Posted: 09/10/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Bob, you mentioned new head gasket. I suggest you have the coolant system checked for combustion chamber gases. The possibility exists for the new gaskets to be leaking. Low cost item.
It looks like the general consensus is to just throw $$ at it, no matter what the cost, instead of analyzing the problem.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
BobsYourUncle
Calgary Alberta Canada
Posted: 09/10/19 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
So you have the original coolant in it ! That would make me nervous also. Dexcool turns to sludge if it gets too hot. Really hard to clean out.
Guess I should have stated myself better and more clearly.
Not the original coolant in there.
What I meant was I have never done the service work of a power flush to clean it out.
When I replaced both heads last summer, the coolant was in fact replaced, just not flushed as we do to clean it all out.
There was a little residual in the bottom of the block, but nothing more.
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
BobsYourUncle
Posted: 09/10/19 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the comments and insight everyone.
I appreciate you all.
