RV.Net Open Roads Forum: Class A Motorhomes: Fuel economy
 > Fuel economy
dalenoel
S.E. Michigan
Posted: 09/10/19 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Average 5000 miles per year at 65 or below. 8.5-9mpg while using Flying J on the truck side, DP. With the toad I can't always get out on the car side but get another 3% back with my AARP Visa so it is another $75 back per year. Don't worry about economy but watch the Silverleaf and see what it is tracking on mileage. We stop every couple hundred miles for the dog and I. Fill up at or before half since we are stopping anyway.
03 Monaco 36PBD DP - 06 Malibu Maxx Toad (SOLD) 18 Focus Toad
08 Jayco Eagle 322FKS (SOLD)
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
bjbear
Cold Lake, AB, Can
Posted: 09/10/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
js218 wrote:
^^^^ I average 50,000 miles per year, currently have 158,000 miles in 3 years.
Wow!! That is a lot of driving (137 miles - 2 1/2 hours driving per day). I could not do that. I don't think too many RVers put on that many miles.
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toad - 2019 Wrangler JL Rubicon Unlimited
My Website
Tom/Barb
Oak Harbor, Wa
Posted: 09/10/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
that's about 150 miles per day.
Cider
Central Oregon
Posted: 09/10/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
Tom/Barb wrote:
Gets me about 9.5 by the computer.
9.5 MPG - c'mon
I always find it interesting how these 36 to 40' + rigs get 9 + mpg driving at 65 MPH or higher. I have a new 35' V10, with all the technology built into it and best I have seen is 8 mpg.
The other point here is if fuel economy and savings on gas is an issue, you are in the wrong form of enjoyment with large RV's. JMO.....
Tom/Barb
Oak Harbor, Wa
Posted: 09/10/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Cider wrote:
way2roll wrote:
9.5 MPG - c'mon
I believe it's all about weight to horse power ratio.
your V10 gas is working harder than my 8.3 diesel.
we usually run light, coach empty weight is 27k, we usually load under 1000#, we don't tow heavy the jeep is only 4288# that brings us across the scales at a little over 32k.
Holding tanks, plus fuel will vary
WILDEBILL308
FORT WORTH , TEXAS
Posted: 09/10/19 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Why are you putting so many miles on? Are you operating a business?
Bill
2003 BOUNDER 38N
5.9 CUMMINS 300 HP
ALLISON 3000MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
js218
on the road
Posted: 09/10/19 11:58am Link  |  Quote  |  Print  |  Notify Moderator
^^^^Nope,purchased it to travel, I'm retired and enjoy traveling. Prior to purchasing the rig I spent 4 years touring the world.
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
DrewE
Vermont
Posted: 09/10/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
A bigger difference than the power to weight ratio for fuel economy is the gas vs. diesel engine. Diesel is about 15% more dense than gasoline and, not at all coincidentally, has about 15% more energy per unit volume than gasoline. Weight has relatively little impact on fuel usage when cruising on a flat road, as it doesn't greatly affect the overall friction of the vehicle which is mostly air resistance at highway speeds. (Weight has a significantly higher impact when going up hills or in stop-and-go driving, of course).
WILDEBILL308
FORT WORTH , TEXAS
Posted: 09/10/19 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
You sound like you are still in "Vacation" mode. Now that you have given it the once over, it is time to slow down and enjoy it. [emoticon]
Bill
PastorCharlie
NC
Posted: 09/10/19 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
My HP to LB. ratio is 66.3 HP to 1LB weight, if loaded to max weight. I never load anywhere close to max weight, always a several thousand lbs. under limit. Therefore the HP to LB ratio is greater than 66.3 to 1. I prefer truck stops and Flying J in particular.
 > Fuel economy
