RV.Net Open Roads Forum: Class A Motorhomes: Class A drive tires
 > Class A drive tires
oldave
Tx
Posted: 09/11/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
The 11R22.5s should be readily available at truck stops that's
why some people choose to run them plus they are usually much
cheaper .
I believe they are actually semi trailer tires
Wherever I happen to park
Posted: 09/11/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Well unless you drive most all day every day those tires like the XRV will age out before they wear out .
XRV's with the FMCA plan will run you about 400 bucks a tire installed (I stress About because installation varies) And are the exact tire for your rig.
I have Toyo's on mine. less than 1/2 of 1% difference in size. the tread life is not as good but re-read the 1st paragraph. they will age out.. 2300 for six of them INSTALLED. (ROunded price actually less).
Home is where I park it.
Tom/Barb
Oak Harbor, Wa
Posted: 09/11/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
We run Michelin 275/70/22.5 they have preformed well, I put them on in 2010 and 70,000 miles ago.
I changed the two steer tires this year. I flat spotted them in the frost heaves on the Al-Can.
