RV.Net Open Roads Forum: Fifth-Wheels: Check valve location
 > Check valve location
wallaceb
Sussex new Jersey
Posted: 09/10/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Settle a discussion. If you add a check valve to PREVENT back flow to the on-board water tank should it be on the house side of the pump or the water tank side, or does it matter not? The trailer does not have a valve to fill the on-board from the CG water connection, only a direct fill. Thank You in advance.
MFL
Midwest
Posted: 09/10/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
I don't think it would matter, but I would put it after the pump if I used a separate valve. I would probably consider replacing the pump, and just go with pump installed valve.
Jerry
Executive
Posted: 09/10/19 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Put it on the spigot and you're good to go....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
troubledwaters
Potomac
Posted: 09/10/19 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I would put it on the intake side of the pump, so the pump stays full of water. YOMV
Old-Biscuit
Verde Valley
Posted: 09/10/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly ^^^^^
IF pump internal check valve is leaking and you put a check vlave in-line on discahrge side of pump the pump casing will depressurize and pressure switch will close causing pump to short cycle.
If you put that check valve in-line on pump suction side then pump casing stays pressurized and pump will only start when SYSTEM pressure drops from opening a faucet etc (OR leak in system)
OR
FIX pump internal chekc valve
wallaceb
Sussex new Jersey
Posted: 09/11/19 05:37am Link  |  Quote  |  Print  |  Notify Moderator
Thank you Old Biscuit, you nailed it. The pump was new last season. Problem is with pump check valve. Install on the tank side is the best solution. Thanks to all.
Tom Cooper
New York
Posted: 09/13/19 04:05am Link  |  Quote  |  Print  |  Notify Moderator
Does it really matter? As far as I know, it makes no difference, well, if, of course, everything is done correctly
Darryl&Rita
Grande Prairie, Alberta
Posted: 09/13/19 06:03am Link  |  Quote  |  Print  |  Notify Moderator
It always matters. Check valves in industrial installs are usually placed downstream of the pump, because of restrictions to flow through them is less noticeable to the discharge.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
