RV.Net Open Roads Forum: How do you really judge TV adequacy anymore?
Search only in Tow Vehicles
 > How do you really judge TV adequacy anymore?
Page of 6
Mickeyfan0805
SE Wisconsin
Posted: 09/10/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
I've spent a lot of time looking at the ever-changing capabilities of pick-ups, and a separate thread earlier today really go me thinking about the uselessness of truck categories. The 1/2, 3/4 and 1-ton badges simply don't mean what they once did. With this in mind,
I went to the 2019 Ford specs and found an F150 with 13k in conventional towing and 2,870 in payload. Meanwhile, I found an F350 with 12,300 in towing and 2,910 in payload.
Now, these are the rarities and the extremes, but it points out the variance in the traditional truck grades, and it makes me ask a question. Even the most conservative rules of thumb, when we first started in the camping world 10 years ago, suggested that one could tow up to 80% of towing capacity. Then, in the 1/2 ton market, we would always say that payload was the limiting factor. The thing is, it's not anymore!
In the F150 case above, the 80% rule would have someone towing a 10,400 pound trailer with an F150, and that would only use 1,200-1,500 pounds of their 2,870 payload - giving them plenty of leeway for passengers and gear.
So, my question is this...How do we judge what is sufficient anymore? How do we know what a truck is realistically capable of? I don't know many F150 owners that would suggest towing a 10k trailer, but one could do that well within the limits of the modern-day specs.
I've always been one to say, 'Know your numbers and live within them.' That is the rule I've followed myself. Now I wonder if that advice is really sufficient anymore.
Old-Biscuit
Verde Valley
Posted: 09/10/19 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
The ole 1/2, 3/4 1 ton designations no longer apply.......haven't for YEARS
What does apply is 'CLASS' Ratings
GVWR Ranges define CLASS
Class I-------up to 6000#
Class II--------up to 10,000#
Class III----------up to 14,000#
GVWR minus UVW equals Payload
For ME........I go by Axle/Tire Load Ratings to determine WHAT Can I Tow?
4x4ord
Alberta
Posted: 09/10/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
I think the manufacturers tow ratings make better sense now than they ever did. The thing people need to be aware of is that HD3/4 tons are identical to 1 tons other than they have less leafs in the rear springs which prevent them from being able to carry much of a trailer. Once the manufactures stop producing these useless 3/4 tons and put the 3/4 ton badging on the 1 ton SRW everything will make sense..... it will be if a half ton won't do it you gets a 3/4 (which will be sprung like a present day 1ton SRW) if the 3/4 ton doesn't cut it you get a 1 ton which means you get duals
2017 F350 SRW Platinum short box 4x4.
B&W Companion
BB_TX
McKinney, Texas
Posted: 09/10/19 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Those 150/1500, 250/2500, and 350/3500 numbers on the side don’t tell much any more. There are so many configuration variations, and subsequent variations in ratings, of each that you have to look in depth the ratings for each and how they were obtained.
Walaby
Georgia
Posted: 09/10/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^^This^^^^^
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
rjstractor
Maple Valley, WA
Posted: 09/10/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
The "80% rule" is made up and has no basis in fact. As the gross combined weight of any tow vehicle increases, performance and durability decline. At the GCWR, a parameter of performance, whether it's braking, acceleration, handling or starting gradeability has declined to the point where one or more of these factors is not acceptable to the manufacturer. An individual's idea of acceptable performance and/or durability may differ from that of the OEM. For some folks it's at 80%, others will pull 1 1/2 times a truck's GCWR and not think twice about it.
A somewhat separate issue discussed ad nauseum on this forum is the fact that in some cases a truck will be overloaded in terms of GVWR or GAWR long before its rated GCWR is reached, and other trucks will hit their GCWR with plenty of gross and axle weight to spare. The moral of the story is that all the various capacities of each truck must be evaluated against a specific trailer to determine whether it's a good fit.
badercubed
Canandaigua, NY
Posted: 09/10/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
This right here.
Consider my Canyon. It's almost a 3/4 ton with 1,470lbs of payload on the door.
2019 Apex Nano 208BHS
2018 GMC Canyon Crew Cab SLE
Been camping for 36 of my 37 years!
BenK
SF BayArea
Posted: 09/10/19 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Those ratings are based, mostly, on a 10% tongue
Real world will mostly be north of that 10% and that will reduce the MTWR and, or payload rating...plus would eat into the rear axle’s rating
Am with old-biscuit...RGAWR is my main, but not only criteria
Will always have tires rated for more than the axle rating
Also, some trailers just tow better...to some are horrible...so just using their weight would be worthless
-Ben Picture of my rig
fj12ryder
Platte City, MO
Posted: 09/10/19 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
"How do you really judge TV adequacy anymore?"
Honestly, if I get over 75 channels, and I can tolerate 7, I consider that adequate.
Howard and Peggy
"Don't Panic"
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 09/10/19 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
You have it all backwards!!! My 2001.5 RAM 2500 with camper option was really a SRW 3500 in a year that RAM did not offer one.
Now GM has just blurred the line with a 2500HD with a GVWR beyond 10K class 2 segment.
It is the 250/2500 that should go away!!! The can I tow this threads would go way down.
In the mean time I will keep my 2015 RAM 3500 SRW with room for 3500+ on the rear axle. Here is 3000+ between the rear axle and tailgate. Try that in your Ford 350 SRW without air bags.
Page of 6
