RV.Net Open Roads Forum: black water holding tank valve opens but won't drain
 > black water holding tank valve opens but won't drain
Fisher Bill
Tigard
Posted: 09/11/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Hey All,
The reason I posted this was so someone else might search this phrase and get a match, I did not (on this site) so after looking around I tried an idea that could get me off the hook.
We went tailgating last Saturday in Eugene, OR and it was dry camping only so I shocked the water system and rinsed into the tanks and went to the water treatment plant.
Hooked up and pulled the cable T handle that runs into the belly through the corrugated plastic, it came out the usual distance but no noise, I put it back in and pulled it out a couple of times but nothing.
So frustrated, I drained the grey tanks, fore and aft and told the guys to limit their bathroom use and so I stewed about it all weekend.
Searched several threads and the net and found an idea that made some sense, I was sure the cable was not broke so here's a recipe I followed.
Take one full bottle of Dawn dish washing soap and pour the whole thing down the toilet and let it sit there for several hours.
Prepare the rig for towing, take and dump 3-5 bags of ice (I did 28#'s) right down the toilet and then hit the road, I went over speed bumps and all of the hilly side streets where I knew the trailer would bounce around a lot and in about 25 minutes I headed for the dump station.
There was a MH and a TT already there and we chatted and I told them what had happened and what I had done and by the time it was my turn they stuck around and low and behold when I opened up the valve we all heard ice cubes come a tumbling down, if I wasn't under the rig it would have been high fives all around.
I know the moral of the story is to take better care of the tank but I thought this was genius, fill with soap and then ice cubes and use the cubes as a huge scrubbing agent to slosh out the tank and scrub the sides while driving and lubricating the slide valve in the process.
I hope this might help others cause it sure helped me.
Bill
2006 Chevy 3500 Dually 6.6 Duramax Diesel & Allison Transmission
2010 Northshore 28RK by Dutchmen
Our first fifth wheel!!!
Morro Bay, CA
Posted: 09/11/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Frequent dumping after intentionally filling the black tank works too.
Cummins12V98
on the road
Posted: 09/11/19 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Moral of the story is to add PLENTY of water to the black tank after flushing.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
philh
Belleville MI
Posted: 09/11/19 10:10am Link  |  Quote  |  Print  |  Notify Moderator
liquid water softener too
laknox
Arizona
Posted: 09/11/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Otherwise known as the GEO Method... [emoticon]
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
pianotuna
Regina, SK, Canada
Posted: 09/11/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
The ice does just about nothing--it is the water and the detergent.
Regards, Don
Cummins12V98
on the road
Posted: 09/11/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
How about simply adding enough water to begin with so these "FIXES" simply don't need to be used!
Fisher Bill
Tigard
Posted: 09/11/19 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
When we deep sea fish for tuna we make an ice slurry in the bow compartment and when it starts to melt we can hear the ice cubes sloshing back and forth rubbing against all sides of the aluminum compartment so I have to believe that 30#'s of ice does something, YRMV
pianotuna
Regina, SK, Canada
Posted: 09/11/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Some one did a lovely test and published it on Youtube. The ice did just about nothing. Nor do the back flush devices work well. Sewer solution works a bit better, if there is a "straight shot" into the tank and if the water pressure is high. Rinse sprayers at the top of the tank do the best.
https://www.youtube.com/watch?v=iH6acEmqvcw&t=20susing ice.
https://www.youtube.com/watch?v=dfTd0Slt_cUComparing Tank Flushers in the Clear RV Black Tank
https://www.youtube.com/watch?v=zYJCLzGaaB8Sewer solution test straight shot 120 psi
* This post was last edited 09/11/19 01:16pm by pianotuna *   View edit history
blofgren
Surrey, B.C.
Posted: 09/11/19 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you very much for sharing your experience. I have always had this scenario in the back of my mind when pulling the black handle, but so far so good!
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
