RV.Net Open Roads Forum: Tech Issues: black plastic waste pipe
 > black plastic waste pipe
wanderingbob
monticeeo, fla
Posted: 09/11/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Three inch plastic waste pipe , is there a way to unglue it or must you cut and start over ?
The valves can you buy a rebuild kit ?
Cummins12V98
on the road
Posted: 09/11/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
There is a tool to cut old pipe out of a ABS fitting. Don't think you want to spend that much $$$.
If you have a bad glued in valve simply buy the same open it up and remove the center slide portion and seals and install in old valve.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Colo Native
Colorado
You can not unglue, You can however cut it and use no hub clamps from your local Home Depot or Lowes. I did this with mine so I could replace the 3" waste valve. Just make sure you cut it straight as possible.
2018 Grand Design 315RLTS
2015 F250 XLT PSD CC SB 4x4
2016 Primetime Crusader 315RST(SOLD)
08 Fleetwood Fiesta 34B(SOLD)
Retired DFD
Artum Snowbird
Campbell River, B.C., Canada
Posted: 09/11/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
My rig has a flexible 3 inch rubber connector between the 3 inch plastic pieces. Had to replace both of them just after I bought it (The old story... we never used the toilet or the shower) Yeah right. Anyway, each piece is a standard household connector readily available. They come with two screw clamps and are easy to install.
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
opnspaces
San Diego Ca
Posted: 09/11/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Cut and replace
Yes
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
ScottG
Bothell Wa.
Posted: 09/11/19 11:05am Link  |  Quote  |  Print  |  Notify Moderator
If you just need a valve, no cutting is required.
Simply buy a new valve, unscrew the 4 small bolts and slide the new valve portion in. You'll end up with extra pipe connections that you don't use.
You need something like this: 3" valve
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
smthbros
WI
Posted: 09/11/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Home Depot sells "Socket Saver" 3" for $13.22
Menards sells "Saver Reamer" 3" for $8.99
Just in case you need one.
Charlie D.
E. Texas-Orange
Posted: 09/11/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
https://www.homedepot.com/p/JSC-3-in-Socket-Saver-J44300/302575482
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
Dave H M
IL
Posted: 09/12/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I have never seen or heard of a glue in waste valve before?
Mine have always been the undo the four bolts and slip the new one in there. [emoticon]
Something new every day.
ScottG
Bothell Wa.
Posted: 09/12/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
That's what I was trying to get them to do in my post. People are hung up on replacing the pipe flanges, which of course is totally unnecessary.
Scott
