RV.Net Open Roads Forum: Class A Motorhomes: Where is the turn signal flasher
 > Where is the turn signal flasher
MrWizard
Traveling
Posted: 09/11/19 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
1996 Ford F53 chassis, 460"
1997 Fleetwood BOUNDER
Radiate The Happy
1997 F53 Bounder 36s
2oldman
Ca
Posted: 09/11/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
1997 turn signal location search
MountainAir05
New Mexico
Posted: 09/11/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Look down around the brake switch for one ( this one is a black in color and square and the other one should be in the fuse box in the dash or at lease that is where ours is.
MrWizard
Traveling
Posted: 09/12/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Ok found it
Dash cluster was stuck, even after undoing the safety strap,
finally got it open, flasher was stuck, melted the plastic on the fuse holder tray, just like in the Webb pictures,
Maybe less damage,
That flasher has a built in Sonalert squealer
Glad to get it out of there, that thing is really Annoying
Will go-to the auto parts store today
Will post pictures, when I get on the laptop
* This post was last edited 09/13/19 09:48pm by MrWizard *   View edit history
MrWizard
Traveling
Posted: 09/13/19 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
being 'smashed up' was the result of using channel locks and a screw driver to pry it out of the socket
Tom Cooper
New York
Posted: 09/14/19 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
By the way, I was just thinking about turning signals. I do not like their brightness. Stumbled upon this subject and remembered. Thank)
MrWizard
Traveling
Posted: 09/14/19 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
i cleaned up the socket, and the contacts, checked for power 'ok got power'
still need to run to the auto parts store for the new blinker relay
right now, i have manual operate turn signals, they blink when i move the turn signal lever, i put in a jumper wire across the (2) points where the flasher/relay plugs in
moving the lever on/off, for left or right, flashes the turn signal for that side
* This post was edited 09/14/19 07:18pm by MrWizard *
MrWizard
Traveling
Posted: 09/15/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Installed new flasher turn signal relay last night
Signals are working like new
mchero
Henniker, NH
Posted: 09/15/19 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Good Job! Keep an eye on that relay to make sure it doesn't overheat those spade connections again.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
mchero
Henniker, NH
Posted: 09/15/19 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
