RV.Net Open Roads Forum: Fifth-Wheels: Slide Out Making Banging Sound
 > Slide Out Making Banging Sound
RobWNY
Jamestown, NY
Posted: 09/11/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
When I extend or retract one of my slide outs, it makes several banging noises that are coming from the underside of the RV. This happens every couple of seconds. I opened up the coroplast and saw nothing out of the ordinary. I also lubed the rails real good while I had the underbelly opened up but it made no difference. What else should I be looking for?
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
wildtoad
Blythewood, SC
Posted: 09/11/19 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Might help to know what brand/type slide mechanism you have. Could there be a tooth of a cog wheel broken if it exists?
Tom Wilds
Blythewood, SC
RobWNY
Jamestown, NY
Posted: 09/11/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
It's a Rack and Pinion slide out in a Forest River Hemisphere 5th Wheel. I don't know who actually manufactures the slide out.
MFL
Midwest
Posted: 09/11/19 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Rack & pinion is likely Lippert. If nothing is catching, or obvious, it could be a damaged tooth on the drive. Could you see the drive gear, when the coroplast was down? Has the slide always open/closed evenly, side to side?
Jerry
RobWNY
Jamestown, NY
Posted: 09/11/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry, Yes. The slide out just started making the banging and still opens and closes evenly. I couldn't see the drive gear but I can open up more of the coroplast and get a better look. I'll have to wait a couple of days though. Rain is heading in for the next 24 hours or so.
RobWNY
Jamestown, NY
Posted: 09/14/19 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately I couldn't locate where my problem is with the slide out without tearing out the whole section of coroplast. I'm just not as limber as I used to be, even with a mechanics creeper/crawler. I decided to have an RV shop find and fix the issue. I couldn't get an appointment before Sept. 24th so until then, I'm SOL.
Edd505
Elephant Butte, NM
Posted: 09/14/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty simple system here is a manual: https://support.lci1.com/documents/embedded-rack-slide-out-system-service-manual
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
jdb7566
minnesota
Posted: 09/15/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I had a like noise from my slide out. My noise was caused from left over construction junk tangled up in the slide mechanism. Wonderful quality control.
RobWNY
Jamestown, NY
Posted: 09/15/19 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I didn't see any left over junk but I do have a nice stiff neck from lifting and holding my head in a position where I could see the rails and gears and motor. My wife finally said to me "let someone 30 years younger than you fix it". So that's what I hope to have happen.
Gjac
Milford, CT
Posted: 09/16/19 07:36am Link  |  Quote  |  Print  |  Notify Moderator
For what it is worth I have that banging noise on mine and it is an electric system with cables and pulleys. I found 3 rollers underneath that support the floor, over the years the rollers wore grooves in the floor. I flattened grooves with a hammer and block of wood and noise was lessened. I suspect the noise was coming from the rollers wandering out side of groove when extending or retracting.
