RV.Net Open Roads Forum: Toy Haulers: Nothing Stays secure!
Search only in Toy Haulers
 > Nothing Stays secure!
chuckFF5
Roanoke, Virginia
Posted: 09/13/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2018 Raptor 355TS. We haul a golf cart or our RZRXP 1000. I cant keep either toy tight in the garage for the life of me. Ive upgraded to big heavy duty ratchet straps and use 4 wheel chocks with the toys ratcheted down hard onto the chocks. Every time i stop for fuel or we get where we are going, they have come loose and have shifted or the wheel is turned all the way one direction or the other. Its so frustrating. Whats the secret?
2003 Ford F250 crew cab 6.0 PSD
2006 Escape (DW'S)
2006 Palomino Puma 282 rkss
1 Hot Wife
2 Black Labs
lincster
Mesa Az
Posted: 09/13/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
What are you connecting the straps to?
Frame?
Suspension?
Tires?
You should be hooking straps to the front and running them towards the rear of the machine.
Then do the opposite for the rear.
Criss Cross pattern if you will.
The wheel turning is no big deal, unless you are connecting your straps to the wheels. Which is not the right way to do it.
2019 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
campinghut
Carstairs Alberta
Posted: 09/13/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Use tire bonnets and problems will be solved (but they are a bit extreme for a golf cart).
Tim And Bev
2018 Mobile Suites 38RSSA, 560w solar, 2800w inverter (3 previous Artic fox trailers, 1 Cedar Creek, 1 Heartland Cyclone. In the last 8 Years)
2019 F350 (Previous trucks 2006, 2008, 2012, 2015, 2017 all Ford F350's)
N-Trouble
NorCal
Posted: 09/13/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
You have to lay down etrack for wheel bonnets. Most arent willing to lay that down in a hauler.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Bedlam
PNW
Posted: 09/13/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I also use wheel bonnets. You can use e-track or just have tie down rings in fixed locations. I prefer e-track because I haul different things based on where we go and like the flexibility of mounting locations. I have three runs down the length with track because it allows me to tie down motorcycles along side each other when I don't bring 4-wheeled vehicles.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
campinghut
Carstairs Alberta
Posted: 09/13/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I also use D Rings with tire bonnets
jhlady
Oregon / Arizona
Posted: 09/13/19 09:45am Link  |  Quote  |  Print  |  Notify Moderator
I stop an hour or so down the road and re-tension my tie down straps as necessary. Once re-tensioned I don't have to do this again until I re-load. Works for me, hope it helps you.
fj12ryder
Platte City, MO
Posted: 09/13/19 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Try using tie downs with carabiners instead of hooks. Maybe try strapping them down solidly using spacers, perhaps wood blocks, between the axles/frames and the floor. Thus you don't give the tires a chance to move any.
Howard and Peggy
"Don't Panic"
joebedford
Sheltering at home
Posted: 09/13/19 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't collapse the suspension completely - you're just asking for damage.
Is it as simple as not putting enough wraps of strap on your ratchet?
I've installed etrack and over-wheel tie downs for DW's trike. It was very difficult to access the hook points for straps. Over-wheel takes 30 seconds.
discovery4us
California
Posted: 09/13/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
I always try to strap the tires and the axles and not compress the suspension of whatever I am tying down. I mention the axles only because I used to rely only on wheel bonnets and on a trip back from Glamis I had two tires go flat basically rendering the bonnets useless.
