RV.Net Open Roads Forum: Would appreciate the groups thoughts on tandem axle issue
 > Would appreciate the groups thoughts on tandem axle issue
bandj0521
Michigan
Posted: 09/13/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
We bought this 2018 Shadow Cruiser 20' TT with rear slide out June 2019. The trailer was supposed to be new. Since purchase we had been waiting to take it back to the dealer for cosmetic warranty repairs we discovered at time of pickup. we took it on one trip three weeks ago (140 miles round trip). I took it back to the dealer two weeks ago for the warranty work to be completed and picked it up last evening.
On the drive home, I was flagged over by a passing construction guy who said i was about to lose my rear axle. I immediately stopped and found the right rear tire of the second axle bowed and showing wire cording four inches across the tire. I limped to a place to change the right rear tire, then limped another 6 miles at 10 miles an hour to my home.
can anyone tell me what would cause this? Again, I only put about 180 miles on the unit since purchase (including back and forth to the dealer). I have been told the axle is probably shot, and may have been put on upside down? I have not idea, but the front axle has a bow (as it should) the rear axle is level.
Appreciate any responses as i await a response from my emails and phone calls to the dealer.
I have pics, but i don't know how to post them in here. Would appreciate help on that too..
thank you,
Jay
https://imgur.com/zTFzvkr
https://imgur.com/M1qz7fw
https://imgur.com/LE6sPqq
* This post was edited 09/14/19 06:44am by bandj0521 *
the bear II
Torrance CA.
Posted: 09/13/19 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
My first thought is the dealer may have placed jacks incorrectly under the axle to jack it up and caused the axle to lose the bow. Or as you wrote the axle is installed upside down which is unlikely since the spring pads would have to be welded on the wrong side of the axle from the factory.
Second thought is a curb or rock strike which bent the axle
Third thought is the tire went bad. This is common with original equipment tires.
Good luck in solving this mystery.
Lynnmor
Red Lion
Posted: 09/13/19 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Photos would help, here is help in posting: Photo Posting
harley4275
Belle River, On
Posted: 09/13/19 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Same thing happened to mine . Undersized axles right from the factory. My rear one straightened out thus causing the both reat tires to wear on the inside on my maiden voyage. Had to rotate tires to get home ...ontario to nefoundland..big trip. .
Front tire was ascue from the start . Could be caused by poor weld from the get go or transport company hitting a curb delivering it. Lippert admitted that axles shouldnt do that so thay shipped 4400# axles and springs in liew of the 3500 # ones on it . I was under weight also. Maybe have bigger axles installed under waranty. Company shipped me 4 new tires too.
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
JIMNLIN
Oklahoma
Posted: 09/13/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hard to say without looking. However its under warranty so call the dealer and get it back to them.
One tire on one side worn like that sound like the axle stub (usually where the axle stub is welded to the axle tubes) was bent like happens as the trailer is drug around a corner and impacts a curb as its side scrubs. Doing so can take the end of the axle out of toe and camber at that end only.
Or the tire was a run flat or at low pressures causing high heat and the tread cap came off.
goducks10
There
Posted: 09/13/19 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
With that low of miles I think it's a case of a poorly welded spindle. Seems like whom ever was welding the spindle on screwed up and welded it on crooked.
It normally takes a while for an over loaded axle to bend enough to get bad tire wear. If you only towed it 140 miles and then figure in how far it was from the factory to your dealer that would be the total miles. Being delivered from the factory it should've been empty so overloading wouldn't be an issue.
mobeewan
Hampton, Va
Posted: 09/13/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer axles are supposed to have a slight upward bow at the center. No bow in the axle means it has been straightened either on purpose or by accident.
carringb
Corvallis, OR
Posted: 09/13/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
There's a good chance it was overloaded during factory delivery, by a truck with the hitch too high. Once the limits of the spring equalizers are reached, the rear axle quickly becomes overloaded. Same with the tires. The proper fix is a new axle and rear tires.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
bandj0521
Michigan
Posted: 09/14/19 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Hi All, thanks for your quick replies, and information. I finally figured out how to link photos I think (see original post).
it certainly appears the rear axle is flat (no bow)
Dealer said "they're working on it with the manufacturer" ...problem is we have (had) a trip planned to Niagara Falls, Lake Champlain and Vermont in two weeks! I know this will not be resolved by then : ( I wonder if they will compensate me for loss of "trailer time"
thanks again
* This post was edited 09/14/19 06:59am by bandj0521 *
Jebby14
Windsor Ontario
Posted: 09/14/19 06:56am Link  |  Quote  |  Print  |  Notify Moderator
^ depends how much they want you to go away and be quiet. cause a fuss, make your displeasure known but don't be threatening or menacing. explain your situation and then when you are met with a negative response start sharing your story with anyone and everyone around.
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
