RV.Net Open Roads Forum: Towing: dumb hitch ball question
Search only in Towing
Open Roads Forum  >  Towing
 > dumb hitch ball question
riven1950
NC
Posted: 09/13/19 03:49pm Link  |  Print  |  Notify Moderator
Can we move our 2500rl Imagine TT safely within a storage facility using the hitch I use for my 22' boat?
I think the boat ball is 2" and the TT E2 hitch is 2 5/16.
Got a medical thing going on and just don't want to handle the E2 unless needed.
WE will be moving about 200 yards on pretty flat land.
Thanks
twodownzero
NM
Posted: 09/13/19 04:14pm Link  |  Print  |  Notify Moderator
As long as it's a 2" ball mount rated for at least 5k pounds, you can probably move it around the yard with that no matter how heavy your beast trailer is.
West & above Bishop, California
ETrailer says “no” and so do I.
https://www.etrailer.com/question-355065.html
MFL
Midwest
Posted: 09/13/19 04:28pm Link  |  Print  |  Notify Moderator
I think it would be safe at low speed on flat ground, for that short distance. A simple trick some use, is to put a heavy rag over the 2" ball to fill the gap, when clamping the hitch to smaller ball.
Jerry
bgum
South Louisiana
Posted: 09/13/19 05:20pm Link  |  Print  |  Notify Moderator
MFL has the best suggestion. Put a heavy shop rag on the ball. With adequate tongues weight you will be good to go for short distances. Be sure to use safety chains and breakaway cable just in case.
riven1950
NC
Posted: 09/13/19 05:43pm Link  |  Print  |  Notify Moderator
Thanks folks. I like the shop rag idea. Great site!
winniman
muskoka Ontario
Posted: 09/13/19 08:33pm Link  |  Print  |  Notify Moderator
If the reason you are not changing balls is because you hate trying to get the ball off the drawtube, just buy another drawtube for the other ball. Those balls are all but impossible to remove. I have a different drawtube for every ball. I have at least 8 or 10 different ones for different trailers we own. Some need a drop, some are raised. 2", 1 7/8, 2 5/16, pintle hitches. Do yourself a favour, and do the safe thing. Just get another drawtube. Then all you have to do is pull a pin to change it. Cheers.
wnjj
Cornelius, Oregon
Posted: 09/13/19 08:47pm Link  |  Print  |  Notify Moderator
It sounds like the OP doesn’t want to lift the heavy ball and drawbar for the 2 5/16 and is actually planning to use a different, lighter drawbar with a 2” ball on it.
whiteeye42
Rock Springs Wyoming
This is just being lazy and unsafe get a new hitch with the right size ball that way you just have to pull a pin and change the hitch and replace the pin
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
Chris Bryant
Arden, North Carolina
Posted: 09/14/19 07:00am Link  |  Print  |  Notify Moderator
Watch dealers move trailer with tractors- they never get out and lock the coupler. No worries, you’ll be fine.
-- Chris Bryant
