RV.Net Open Roads Forum: Truck Campers: Ford aluminum trucks
 > Ford aluminum trucks
dennych1
Long Island New York
Posted: 09/14/19 07:59am Link  |  Print  |  Notify Moderator
Has anybody have any experience with the aluminum trucks with there truck camper .
Kayteg1
California > Nevada
Posted: 09/14/19 08:36am Link  |  Print  |  Notify Moderator
Just put over 8000 miles this summer for total about 30k.
Aluminium bed shaves about 900 lb from the rear, so my 6000 lb camper goes without any modifications.
I only add Sulastic hangers for empty ride comfort.
dennych1
Posted: 09/14/19 09:16am Link  |  Print  |  Notify Moderator
Do you have a f350. Also what is sulastic hangers never heard of that
Kayteg1
California > Nevada
Posted: 09/14/19 09:43am Link  |  Print  |  Notify Moderator
F350 like in my footnote.
Google Sulastic hangers. It is the best $300 I spend on the truck.
Posted: 09/14/19 02:03pm Link  |  Print  |  Notify Moderator
That's a phenomenal weight reduction for the aluminum bed!
Considering a normal steel 8' bed weighs maybe 400lbs, maybe 500lbs tops with dually fenders, having a truck bed that weighs negative 400lbs is awesome!
Ski Pro 3
bye
Posted: 09/14/19 08:14pm Link  |  Print  |  Notify Moderator
06 Dodge Ram 3500 with an 8' bed that had been sprayed with Line-X ~1/8-3/16" thick. 412.26 pounds
burningman
Seattle, WA USA
Posted: 09/14/19 10:18pm Link  |  Print  |  Notify Moderator
90 pounds lighter is closer to the truth.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Popparex
same as typed
Posted: 09/15/19 07:02am Link  |  Print  |  Notify Moderator
I have a 2019 f350 dually and it dents when you look at it too hard. Other than that i have no complaints so far. Have only 5K miles on it so far. i was told (but the specs above may dispute it...) that they took the weight savings and beefed up the transmission and other areas...?
OH48Lt
Whitehouse, OH
Posted: 09/15/19 07:24am Link  |  Print  |  Notify Moderator
Total weight savings for a typical F150 crew cab 2015-up is about 700 pounds. YMMV. Walk through a parking lot with a bunch of aluminum Fords in there and see if you can find dents in an amount any different than steel trucks.
2017 Ford F-150 Crew Cab 4x4 3.5 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
2019 Mustang Bullitt
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
JimK-NY
NY
Posted: 09/15/19 08:09am Link  |  Print  |  Notify Moderator
Ford claims to have saved hundreds of pounds. Those savings do not just reflect the aluminum bed. Of course, other manufacturers are also making weight reduction modifications elsewhere on their vehicles.
After years of use and hitting bumps occasionally, my steel Dodge Ram bed showed considerable damage. Aluminum would have been much worse. I would suggest adding a plywood base if you have an aluminum bed.
