RV.Net Open Roads Forum: Heading to the Rockies for 5 or 6 weeks.
 > Heading to the Rockies for 5 or 6 weeks.
bid_time
Michigan
Posted: 09/19/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
The minute my F150 is picking up speed while coasting (in tow/haul mode) and I touch the brakes, the tranny downshift (sometimes more than 1 gear) and engine braking comes in.
lbrjet
Gold Canyon, AZ
Posted: 09/19/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Desert Captain wrote:
"I don't know how anyone could tell that I was not using tow/haul by what I wrote."
No offense intended but this is what you wrote, sounded like you weren't using Tow Haul:
"On the downhill runs however, the engine is still a 3.5 liter gasser when it comes to motor braking. I have to use my brakes more than I would like on the long high speed drops. Today I came down what is probably my steepest, curviest downhill in my driving experience. This road was handled well by the EB because the speed limit was 25 and I could use first gear and had very good speed control with engine braking."
If you are in TH you should not have to use your brakes much at all. A light tap of the brake pedal will downshift the trans one gear, no need to manually shift down unless that's what you like to do though it does seem a tad redundant.
On a long 5 or 6 percent grade I select a speed that is appropriate for the road conditions and set cruise control while in Tow Haul. This usually gets me to the bottom of the grade without ever touching the brakes or at most doing so lightly and not often.
As always... Opinions and YMMV.
[emoticon]
I believe the OP's point was that a 3.5L V6 doesn't have the same engine braking capability as a 5 or 6 liter engine. The turbo is great for going up, but doesn't help you going down.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
flguppie
Treasure Coast-FL
Posted: 09/20/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Is it the engine size or transmission?
I went from a: 2010 F150 5.4L V8 with 6 speed Tran that was slow on the uphill climbs but great with tow-haul going down hill
I now have a:
2018 3.5 EgoBoost V6 with 10 speed Tran that was awesome on the uphill climbs and OK on the downhills with tow-haul. I may be tapping the brakes a few more times going down to get it to shift to a lower gear because I now have more gears....I figure that is a transmission difference, not block size. I have noticed rpm stays higher longer at the end of the hill run and it takes longer to get the Tran to shift back to a higher gear after once down.
FL-Guppie "small fish in a big pond"
2014 KZSpree Connect 220rbk
2018 Ford F150 SuperCrew 3.5L Ecoboost, maxtow
Posted: 09/20/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
No, you just don’t get the same compression braking with less engine volume and cylinders, especially combined with forced induction.
