RV.Net Open Roads Forum: Tow Vehicles: 4.10 rear in new Ford F350
Search only in Tow Vehicles
 > 4.10 rear in new Ford F350
Posted: 09/19/19 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
^ Lol, right?
Methinks the OP doesn’t know there’s a difference.
In short. Gasser, if towing anything significant, get the deepest gears you can for the best performance. Diesel has 2x+ the torque of the gasser so you can tow pretty heavy with taller gears easily.
spud1957
NB
Posted: 09/20/19 03:22am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Gas or diesel and towing what?
4:10s are only available in the DRW diesel in the 350. Need to step up to the 450 to get 4:30s. And the 450 only comes with the diesel.
4:30s only in the gasser.
4x4ord
Alberta
Posted: 09/20/19 04:44am Link  |  Quote  |  Print  |  Notify Moderator
The differeonce in 60mph high gear cruising rpm between 3.55 and 4.10 is 1524 rpm vs 1760 rpm. The power required to tow a 16k 5ver at 60 mph on level ground is only about 100 hp. The 6.7 can produce 320 hp at 1800 rpm. When peak hp is needed in the hills the 4.10 rear gears will have the transmission in 5th and the engine running 2260 rpm at 60 mph. The 3.55 gears would put the transmission in 4th gear with the engine running 2616 rpm. So the 3.55 gears are going to out pull the 4.10 gears on hills that the truck is capable of climbing at 60 mph. It takes a pretty steep hill or a very heavy trailer before the 4.10 gears offer the advantage.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Huntindog
Phoenix AZ
Posted: 09/20/19 04:58am Link  |  Quote  |  Print  |  Notify Moderator
Ummm. Fords max specs need the 4.10s. OP doesn't state what he will be towing. Just that he will have a 5500# camper, AND towing something occasionally.. He may be pushing that truck pretty hard.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
dodge guy
Bartlett IL
Posted: 09/20/19 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Yep Exactly! The 4.10's are the way to go. It'll walk right past a similarly loaded 3.73 truck.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Vanished
Central PA
Posted: 09/20/19 06:39am Link  |  Quote  |  Print  |  Notify Moderator
We have a new '19 F350 diesel DRW w/ 4.10's - 15k trailer and 2k trip averaged about 11 mpg...
2019 Ford F350 4x4 diesel DRW
Posted: 09/20/19 09:59am Link  |  Quote  |  Print  |  Notify Moderator
And now we have the tall gears will out pull the low gears guys checking in.
Regardless of gas/diesel, number of trans gears, apples to apples, lower gears put more power to the ground.
I spose one could cherry pick one particular situation where the trans gears and torque curve of a particular vehicle might favor taller gears, but that will be a very select case.
Or all the mechanical engineers and theory are wrong......
Wonder why trucks with deeper gears generally are rated to tow more??
dennych1
Long Island New York
Posted: 09/20/19 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all this info while researching new truck
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 09/20/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Back when trucks had 3 and 4 speed tranny's gear ratio really mattered. Now with 6-10 transmission we can look at final gear ratio based on the tranny gear in use.
Example the RAM with 3.42/Aisin in 5th has almost an identical final gear ratio was 4.10 truck in 6th gear.
The 4.10 truck in 6th is work against a .63 OD ratio while the 3.42 truck is in 5th working against a .77 OD ratio.
4.1 x 0.63=2.583
3.42 x 0.77=2.6334
Now add in the shorter tires on the dually with 4.10 and it is a wash. What you think you gain with the lower diff gears in negated by the steeper OD ratio. Think final gear ratio!
Lynnmor
Red Lion
Posted: 09/20/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that the transmission is worked harder with higher diff gears.
You multiply the top gear ratio times the diff gear ratio, and the result is always more torque with the lower rear gears. Add to that, each gear change is less of a difference in road speed, keeping the engine at a better RPM.
