RV.Net Open Roads Forum: Tech Issues: DC Power Issue
 > DC Power Issue
SolanaJohn
San Diego
Posted: 09/20/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the help and suggestions. Breaker is not tripping. I get 12.8 volts across battery and also from battery neg to both sides of breaker both before and after power shuts off. Also, I found that I am unable to reset the system (get any lights to work or controller panel to function) unless I uncover the solar panel and plug into shore power briefly. I can then cover panel before proceeding to turn on enough lights to make everything shut down.
theoldwizard1
SE MI
Posted: 09/20/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
SolanaJohn wrote:
With shore power disconnected: battery shows 12.9V and DC fuse panel is 12.6 V.
With shore power connected: battery shows 14.6V and DC fuse panel is 13.6 V.
With shore power disconnected and solar panels uncovered in full light: battery shows 14.5V
So I conclude wiring from solar panels to battery is ok and wiring from battery to DC fuse panel is ok.
I disagree ! There should be ZERO voltage difference (drop) between the battery and the fuse panel.
SolanaJohn
San Diego
Posted: 09/20/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
@theoldwizard1, thanks! I checked this again (twice) and voltage across battery matches voltage from battery negative to DC fuse panel. Must have been poor measurement technique first time.
SolanaJohn
San Diego
Posted: 09/21/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
I ran through all the voltage checks again:
Shore power off (no power to trailer)
Solar panels not covered/full sun.
Solar controller panel reads error (can’t detect a battery)
Across battery: 12.8V
Battery - to fuse + : 12.8V
Battery - to CB near battery: both sides 12.8V
Cover solar panels
Solar controller panel goes blank
Across battery: 12.75V
Battery - to fuse + : 12.75V
Battery - to CB near battery: both sides 12.75V
Plug in shore power (solar panels still covered)
Solar controller panel indicates 13.7V (no indication that battery is being charged)
Across battery: 12.77V
Battery - to fuse + : 12.77V
Solar controller reads charging up to “13.8V / Full”
Unplug shore power
Across battery: 13.58V
Battery - to fuse + : 13.58V
Cover Solar panels
Across battery: 12.9V
Battery - to fuse +: 12.9V
Controller panel shows 12.7V
Turn on lights sequentially until all lights fail.
Turn off all light switches. Switch on lights (none light).
Return all light switches to off position.
Across battery 12.8V
Next steps/any ideas?
CA Traveler
The Western States
Posted: 09/21/19 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
STOP TMI in your post.
Find out why your shore power charger is not charging the battery. You have an open somewhere, bad charger or miswired wiring.
Your post implies the charger is connected to the solar panels and not the battery. [emoticon] Suggest to completely disconnect the panel wires and the solar controller output wires.
Start with the obvious things than need fixing and proceed until it all works.
2014 Grand Cherokee Overland
Bob
Sam Spade
North Central Florida
Posted: 09/21/19 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
You are barking up the wrong tree, so to speak.
You NEED to do a similar set of measurements WHILE THE LIGHTS ARE FAILING.
I suggest that you disconnect the solar system completely and then make some more measurements.
It should be bridged in parallel with the batteries and converter/charger and should NOT be causing what you are seeing even if it is failing.......unless someone has made a huge wiring error.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
SolanaJohn
San Diego
Posted: 09/21/19 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Hmm. I thought more info = better. None of this is obvious to me so... does anyone know of a good electrician/shop in the San Diego area?
Thanks!
time2roll
Posted: 09/21/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Load it up until power cuts off as originally stated. Then with everything failing to work check your battery voltage. If you have battery voltage above 12 then find the open connection. If battery voltage is dropping then have the batteries checked.
675w Solar pictures back up
SolanaJohn
San Diego
Posted: 09/21/19 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I did this already and since battery is over 12 volts (12.8) that means an open circuit? OK, but since battery to fuse is also 12.8 volts then does that imply open circuit is between fuse and lights?
time2roll
Posted: 09/21/19 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Keep checking until you find some device or connection with 12.8 on one side and near zero on the other.
 > DC Power Issue
