RV.Net Open Roads Forum: Tech Issues: Tecma Toilet impeller issue ?
 > Tecma Toilet impeller issue ?
JoeH
Apollo Beach,FL
Posted: 09/20/19 06:09am Link  |  Quote  |  Print  |  Notify Moderator
My rear bath toilet is not flushing. I am thinking the impeller is toast as I hear the motor spinning, but no flushing occurs. Just wondering if anyone has taken theirs apart and if there are any precautions . Good thing is there is nothing but water in the toilet so I don't have to worry about that aspect, other than sponging out the water before removing it.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
rdhetrick
Posted: 09/20/19 06:17am Link  |  Quote  |  Print  |  Notify Moderator
I had mine do the same thing once. In my case, somehow the main "drain" hose got twisted enough to essentially pinch off the flow - like a kink in a garden hose.
I re-adjusted the hose and re-tightened the clamps and it's been fine since then.
Rob
2006 Mandalay 40E Full Time
2015 Jeep Grand Cherokee
hypoxia
Arizona
Posted: 09/20/19 06:50am Link  |  Quote  |  Print  |  Notify Moderator
In case you don't have it
Tecma Manual
Just thinking, my Sanicon Turbo 600S mascerator does that sometimes, it's the same motor and impeller as the Tecma, I shake it and turn it on it's side and it clears. I have two Tecma toilets. What color is the toilet LED?
Jim
2007 Monaco Signature Noble III ISX 600HP
JoeH
Apollo Beach,FL
Posted: 09/20/19 07:06am Link  |  Quote  |  Print  |  Notify Moderator
The LED is green.... I can hear the motor run when I push the button, but the water stays in the bowl. I'll look at taking it apart in a few days , just don't know if there are parts available as the manual I've seen just have the motor assembly, not the individual parts like impeller and seals.
