RV.Net Open Roads Forum: General RVing Issues: Valve extenders safe?
 > Valve extenders safe?
IAMICHABOD
Sunny So Cal 90713
Posted: 09/22/19 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
The last thing you want to do is put those flexible extenders on your valve stems. They have a tendency to leak and if they get loose from the anchoring point they can flop around and not only do damage to your wheel but suddenly deflate the tire causing a catastrophic loss. I can speak from experience,this happened with my old Class A.
What is needed is a extended valve stem that will let you quickly check your tire pressure. They add no extra weight like the Extenders would and balancing is no problem, TPMS works on them as well
Something like the Duallyvalve I have a set like them and I never have to take my simulators off to check the air pressure.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
magicbus
Nantucket Island, MA
Posted: 09/22/19 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Buy quality, install correctly and you are fine. Two years and 10,000 miles and no crises yet.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
Airdaile
On The Road
Posted: 09/22/19 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
The stainless braided ones tend to leak if under constant pressure.
jplante4
Cape Cod
Posted: 09/22/19 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Every braided steel extended I've use has either leaked or the pop rivets have pulled out of the hub. With and without TPMS sensors. Next time I buy tires, I'm having the shop put in these.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
mgirardo
Brunswick, GA
Posted: 09/23/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
Our Jayco Class C came with valve stem extenders. They worked okay. We had a problem once when I went to air up one of the inner dual tire and it wouldn't take air. I had to pull the simulator, remove the extender and put it back on. I had to do this twice before it finally started to work properly.
When we replaced the tires, we had the tire shop install Tire-Man Dually Valve Stem kit. These made checking and airing up the tires so much easier (even easier than with the valve stem extenders).
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
IAMICHABOD
Sunny So Cal 90713
Posted: 09/23/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
-Michael
I also purchased the Tire Man extended Valve Stems,several years ago and I am very happy with them.
The problem is that Chuck,the original designer of them has passed away and it seems that His business has passed with him.
The only alternative to his is the BORG line. They are a copy of Chuck's original design,and I am told they work well.
cwit
Upstate New York
Posted: 09/23/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have the braided stainless , been on the 5 years I have owned and we’re on when we bought it.. I can check both Dulles no problem.
Jennifer Koper
494 Norman Street
Posted: 09/24/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Dear all, I am waiting for the below updated information.
I want to add air to tires for 2013 cayenne. Is it ok to use ordinary air?
fj12ryder
Platte City, MO
Posted: 09/24/19 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
It depends on whether it's a mid-year Cayenne, the Cayenne's made after October 27th will not accept any air with an oxygen level of more than 7.2%. This occurred for the three months after that date, any Cayenne's made before or after that date have no issues with standard air. Although they may be down a bit on pepper, and acceleration may suffer.
Howard and Peggy
"Don't Panic"
ncrowley
Utah
Posted: 09/24/19 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Use the Borg one piece extended valves. They are solid and quality. No issues with leaking.
Nancy
Newmar Northern Star
