RV.Net Open Roads Forum: Tow Vehicles: Wierd Marks Appearing On Tires
Search only in Tow Vehicles
 > Wierd Marks Appearing On Tires
PointyWombat
Calgary, AB, Canada
Posted: 09/22/19 12:25am Link  |  Quote  |  Print  |  Notify Moderator
These vertical marks around the tire circumfrence stared to appear on the rear tires of my 2012 silverado 3500 SRW. I recently rotated my tires and front tires did not have these marks. Since rotating, the marks have started to appear after approx 3000 miles. I tow occationally a ~11k lb. fiver. I've towed several times since rotating.
The tires are Cooper Discoverer X/T4 with approximately 35000 miles.
https://imgur.com/gallery/8L5vgwE
Any thoughts on what these indicate would be appreciated.
Thanks,
PW
2012 Silverado 3500 Diesel SRW
2013 Bighorn 3010RE
4x4ord
Alberta
Posted: 09/22/19 03:39am Link  |  Quote  |  Print  |  Notify Moderator
[image]Click For Full-Size Image.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
ADAD437
Jeffersonville,Ind., webster,fl. USA
Posted: 09/22/19 05:01am Link  |  Quote  |  Print  |  Notify Moderator
looks like something is rubbing the tire when loaded.
James,Gail & Pancho
2005 georgie boy Pursuit
97chevor
US
Posted: 09/22/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I don't see what is wrong with the tire?
dodge guy
Bartlett IL
Posted: 09/22/19 05:35am Link  |  Quote  |  Print  |  Notify Moderator
Looks like a tire replacement indicator. On some tires they show up when they are nearing replacement. And from the looks of the tires they are due anyway.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
mich800
Pontiac, MI
Posted: 09/22/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
I have never seen a wear bar like that just the raised patches between tread blocks also shown in the pic. I looks like something is rubbing. Do they show on both sides?
mich800
Pontiac, MI
Posted: 09/22/19 05:48am Link  |  Quote  |  Print  |  Notify Moderator
After enlarging the pic it does look like they are molded in. The groove does not cut through the edge of the tread blocks. If that is a wear indicator that is a new one for me. Interesting what it really is.
Terryallan
Foothills NC
Posted: 09/22/19 06:25am Link  |  Quote  |  Print  |  Notify Moderator
I don't any thing but a the tire wearing more in the middle than the edges. Prolly from over inflation.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
CaLBaR
Ontario, Canada
Posted: 09/22/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
I think it might be a replacement indicator. With all of the sipping not sure but look like a winter or true 4 season tire. Winter tires and true 4 season tires with the mountain snowflake have a second set of wear indicators to show when there is not enough tread left to be safe in winter conditions.
If you have the severe winter mountain snowflake on these tires I am pretty sure that is what this vertical line is.
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
Tyler0215
Iowa
Posted: 09/22/19 06:56am Link  |  Quote  |  Print  |  Notify Moderator
With 35K miles you are ready for new tires.
