RV.Net Open Roads Forum: This is what happens when you have too much tongue weight...
 > This is what happens when you have too much tongue weight...
Page of 8
JRscooby
Indepmo
Posted: 09/23/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Over the years I have seen a few light pickups bent that way from pulling compresses and gen-sets, but never that bad. But I would think the driveshaft would stop that much bend...
jimh425
Western MT
Posted: 09/23/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Same trailer and camper on two different Ford trucks. What are the odds ... that either is true?
wnjj
Cornelius, Oregon
Posted: 09/23/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
If he didn't figure out and change what caused it the first time, the odds are plenty good that it could happen again.
zcookiemonstar
Midwest
Posted: 09/23/19 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
There is a video of it driving down the road lie this on a facebook truck camper page.
work2much
Jackson Ca
Posted: 09/23/19 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
For those with facebook.
https://www.facebook.com/leona.pelke/videos/10157795712404669/
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
mi.drew
Greenbush, Michigan
Posted: 09/24/19 03:59am Link  |  Quote  |  Print  |  Notify Moderator
Why would any drivers sit in the driver's seat as though he was going to continue down the road? How did the bottom of the box not touch the bottom of the cab corner in a bending position like that? And how could you drive it without modifications did the drive shaft because I wouldn't line up with the rear end? Too many variables for me to believe. Out there
ajriding
st clair
Posted: 09/24/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
Can you say Photoshop?
haha, same TC, same trailer, photoshopped truck. So, is the broken frame even real?
I'm not an expert on either of these trucks, but shouldn't the frame be more stressed over the axle where the springs mount to the frame and bend there or behind the axle or where the trailer hitch attaches through holes in the frame instead of way up in the middle of the truck?
Others are saying they have seen trucks bend in the middle so maybe this is where a bend would happen… Given the fakeness of this it brings it all into question
Also, yes, the driveshaft would quickly bottom out inside the transmission and stop the axle from rotating. What happens then? The stress gets put on the axle? Leaf springs would hold the bumper suspended above the pavement maybe, what would coils do?
Kayteg1
California > Nevada
Posted: 09/24/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
The page took over a minute to open, but when I click on video, it will show loading for couple of minutes and nothing happens.
Is the video there?
work2much
Jackson Ca
Posted: 09/24/19 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Video is working for me. There are a number of comments on the video from people who also saw the truck/camper as well as a couple moe pictures people took of it. Here is a still from the video. There is some pretty bad scraping/grinding noises coming from the truck.
As far as the driveshaft, not sure about Ford but on our Rams the driveshaft is 2 piece which would allow for some extreme angles
joerg68
St. Ingbert, Germany
Posted: 09/24/19 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
very strange indeed.
The photo of the truck with the two-tone paint dates back to at least 2014 (you can do a reverse image search)
At the time, it was discussed here.
I think I remember someone saying that there was a race car in the trailer, and a heavy toolbox in the front of the trailer.
The all-white truck seems to carry the exact same camper and pull the exact same trailer.
Photoshop is possible in a still ... but in the fb video? The video clearly shows the bent all-white truck. And even if it were 'shopped ... why?
But the other explanation is just as crazy: same thing happening to same person with new truck?
I do not doubt the truck was drivable. There is a similar video out there of a truck bent by a fallen tree.
Strange, this...
Page of 8
