RV.Net Open Roads Forum: This is what happens when you have too much tongue weight...
 > This is what happens when you have too much tongue weight...
Page of 8
work2much
Jackson Ca
Posted: 09/24/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
I'm curious if the first truck was a 350. After bending it he went with the 450. Given that the spotting of this truck seemed to be in Canada I'm also wondering if hitting a big ice heave could have been responsible. We went through Canada a couple years ago and some of those dips are no joke. Combined with a heavy camper and too much tongue weight from that long trailer extension could put a huge momentary load on the back end of the truck frame.
Hard to fathom breaking a second truck in the same way as the first. Not much of a learning curve...
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2018 Jeep Wrangler Unlimited toad.
Kayteg1
California > Nevada
Posted: 09/24/19 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
Now the facebook page got poofed.
More and more mystery.
JRscooby
Indepmo
Posted: 09/25/19 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Does the tongue extension increase the down pressure on the ball? As long as I remember I have used a longer bar when I needed to lift more...
Kayteg1
California > Nevada
Posted: 09/25/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Shorter hitch = less weight on the axle and less stress on the frame.
I used my F450 with 18,000 trailer and I had it loaded to the degree when front wheels were barely having any load and I had to use trailer brakes alone to have control during slowing down.
The frame had not even indication of being stress, although C&C frames are different that those made for normal beds.
Bottom line, I am not buying Ford frame can bend like that, even less that it was drive able.
wnjj
Cornelius, Oregon
Posted: 09/25/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
So you’re saying someone faked at least two pictures and a video? I watched the video and it seems to be driving fine, though a little slowly. Why is this so tough for people to believe?
The video link on the previous page still plays fine for me and I don’t have a Facebook account.
JRscooby
Indepmo
Posted: 09/25/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I think you mean a longer ball to axle of TV will put a higher percentage of TW on the rear axle of TV. Which means extending the hitch back would be bad. I agree. OTOH, looking at the picture, the ball is in the stock location, but they extended the tongue, moving the coupler away from the trailer axles. This would reduce the down pressure coupler to ball, reduce stress on frame.
For the TW alone to cause this issue you would need the tongue and extension to be stronger then the 2 frame rails. Wiley is looking around, past the cliff edge.
Kayteg1
California > Nevada
Posted: 09/25/19 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Yesterday I was getting message that the video got removed, although it plays today.
Still
-why the photographer stop recording in most interesting point?
-why the situation, who happened years ago made it to facebook 3 months ago?
The pictures show the tie-downs on the ground, when you don't see any sparks on video.
Hard to believe situation like that would not make any more headlines. If it was real...
Would your truck bend like that, would you continue driving without unhooking the trailer?
wnjj
Cornelius, Oregon
Posted: 09/25/19 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Still
-I don't know why it stops but there's enough to see in what's there.
-The two tone truck happened years ago. I'm assuming the white one happened recently.
-Hard to see sparks in the daytime but you can sure hear it dragging.
-He was driving slow with the hazzard lights on and likely not far. I would too if I wanted my rig off the highway. The hitch was probably too bound up to disconnect and/or the camper is sitting on it.
I defer to Occam's razor for this one.
Fordlover
Spring, Texas
Posted: 09/25/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
I'm beginning to believe this is a result of modifications the owner is doing. for a 350 and a 450 to fail apparently in the exact same way... Perhaps he's doing something to the frame to accomodate the hitch and it is weakening the frame and allowing it to bend in the same spot. The lengthened tongue on the trailer looks like a custom job/shade tree engineering job.
I'd think he would have learned his lesson after the first one! The frame on my 250 is way weaker than the 450, and mine hasn't bent even one time. [emoticon]
2016 Skyline Layton Javelin 285BH
2018 F-250 Lariat Crew 6.2 Gas 4x4 FX4 4.30 Gear
2007 Infiniti G35 Sport 6 speed daily driver
Retired 2002 Ford Explorer 4.6 V8 4x4
Sold 2007 Crossroads Sunset Trail ST19CK
Eric&Lisa
Scappoose, OR
Posted: 09/25/19 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like the same camper.
Looks like the same trailer.
Looks like a *different* truck (but similar).
Looks like a *different* location.
My conclusion: Same owner, different events.
Supposition: The owner did something stupid and broke his truck. Got a replacement truck that was similar but not identical. Did the same stupid thing.
Thinking through the physics... That would take a heck-of-a-lot of weight behind the rear axle to cause the front end of the truck to pop up. I cannot believe that Ford, or anyone else, would design a frame so weak that it would break in two. Not to mention if there really was that much weight behind the rear axle, that would have lowered the weight on the front wheels and made this a bastard to drive and brake.
This picture:
Look at where the front tie-downs are mounted. Total WAG on my part... What if they were welded in place by someone who didn't know what they are doing? If heated & cooled improperly, metal can lose its strength. It is not a big stretch on my part to see someone screw up a front tie-down install and weaken that critical part of the frame... "I'm gonna redneck weld this in place so good that it will never break off."....and they end up with a weak spot at the most critical structural point of the frame.
Alternative possibility... Maybe a bad bump at too high of speed broke the frame downward, and the resulting weight distribution generated these pictures after it stopped?
Just one guy's armchair analysis...
-Eric
Eric & Lisa - Oregon
'97 Silverado K2500, New HT383 motor!, Airbags, anti-sway bar
'03 Lance model 1030, generator, solar,
Page of 8
