RV.Net Open Roads Forum: Fifth-Wheels: Coiled outside shower
 > Coiled outside shower
bobbyg123
Duvall, WA
Posted: 09/23/19 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Another of my many stupid questions...
My new rig has an outside shower with one of the newer coiled, quick connect attachments. I can't for the life of me figure out how to connect the darn thing. I push back the nozzle the way you're supposed to, but it doesn't fully attach. I was able to winterize it, but I got drenched in antifreeze because it wouldn't fully connect.
2018 Jayco Eagle HT 29.5BHDS
2017 Ford F-350 CC 6.2L
ford truck guy
Pennsylvania
Posted: 09/23/19 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
my last 3 all had/have that.. It is a Royal P.I.T.A to get all the way inserted, You have to really push the coupling ring ALL THE WAY BACK for it to accept the male part of the hose....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
C.B.
APPLETON WI USA
Posted: 09/23/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Try this. It helped with mine.
Push the coupler back and spray wd-40 in between the part that slides and the inner part that doesn't. Also put wd-40 on male part before insterting.
I've had to lubricate my air fittings also. On those I use oil.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
Learjet
Louisiana
Posted: 09/23/19 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
push collar in, insert male end, then while pushing in...pull the collar out to seat the collar
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
BB_TX
McKinney, Texas
Posted: 09/23/19 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I used some plumbers silicon grease on mine. Yep, they are a PITA.
whiteeye42
Rock Springs Wyoming
Posted: 09/23/19 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Or you can do what i did i disconnected mine all together that way i don't have to winterizer it in all the different trailers i have owned we have only used the outside shower once.
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
12thgenusa
Loveland, Colorado
Posted: 09/23/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off the pump or city water, open a tap to bleed the pressure and the quick connect is much easier to connect/disconnect.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
fj12ryder
Platte City, MO
Posted: 09/24/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
The water pressure has no effect on the quick disconnect unless the faucet is turned on. Ours works pretty well, but does take a bit of a push to get it to engage.
Howard and Peggy
"Don't Panic"
schlep1967
Harrisburg, PA
Posted: 09/24/19 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Mine sticks from lack of use. Makes it impossible to push the quick connect in. I take a srew driver and put it into the hole and give it a light smack with my hand. Once I do that I can easily insert the quick connect. YMMV
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
blofgren
Surrey, B.C.
Posted: 09/24/19 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
They are difficult to get connected properly; to make it worse the last time I used mine I got soaked anyway because the hose developed a bunch of small cracks. [emoticon]
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
