RV.Net Open Roads Forum: Toy Haulers: Man, I screwed up!! Water Damage
Search only in Toy Haulers
 > Man, I screwed up!! Water Damage
William Willard
Brookins Oregon
Posted: 09/23/19 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Ben -- I live in Gilbert & work on RV`s here at my home shop -- If you like, pull the trailer over & I`ll have a look & give you a guesstomate on what it will take to repair the damage -- All`s not lost -- I have a motorhome here now that was neglected & now the bedroom paneling is mush -- So you`re not the only one with problems -- The impossible only takes a little longer -- Bill Willard 480-540-7377
12th Man Fan
Flower Mound , Texas
Posted: 09/23/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Check your clerance lights across the front also. This sometimes can be the source of a leak.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
gbopp
The Keystone State
Posted: 09/23/19 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
After you get the damage repaired, seal all the roof seams and edges with Eternabond.
AzHunter79
Scottsdale
Posted: 09/23/19 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a 50ft roll of the stuff already. When doing the edges, are you basically folding it over the edges so its like a 90 degree elbow?
BB_TX
McKinney, Texas
Posted: 09/23/19 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Black mold can be a significant health issue. From your description, as a minimum I would want the front cap removed, and proceed from there as to how much else is needed.
Companies that clean and remove black mold work in full hazmat protective gear.
AzHunter79
Scottsdale
Posted: 09/23/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
I 100% agree. The plan will be to remove the whole front cap and remedy the mold first. I couldn't do that yesterday because I was worried I wouldn't be able to get it back on to tow it as it's 2 hours away from my house
nayther
Burbank, CA
Posted: 09/24/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
consult with a mold expert. If it's black mold it's nothing to mess with until neutralized. I believe bleach solution will kill it.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
CA Traveler
The Western States
Posted: 09/24/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I doubt you will get any compensation for the leak. Who will do the repairs for you?
And with the front leaking expect other leaks visible or not. Pull everything you can - drawers, cabinet sides/floors etc inspect for water marks and dry rot with a ice pick. Go over every square inch looking for issues.
2014 Grand Cherokee Overland
Bob
gbopp
The Keystone State
Posted: 09/24/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Yes. I put the Eternabond about 1/2 inch onto the rain gutter. It the sealed the edges. If I didn't have a gutter I would have attached it to the side wall. Take your time and apply it straight/level.
AzHunter79
Scottsdale
Posted: 09/24/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Did you do the whole side with one piece or cut sections to make it easier?
