RV.Net Open Roads Forum: Class A Motorhomes: Hitch upgrade question.
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Hitch upgrade question.
Bobalooie
Canada
Posted: 09/23/19 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2000 Dutch Star with a GCWR rating of 39,000 and GAWR of 29,000lbs. According to the manual, it supposedly has a 5000lb hitch, but I know it can have 10,000. Can one just have a higher rated hitch installed without having to beef up the frame?
wolfe10
Posted: 09/24/19 06:22am Link  |  Quote  |  Print  |  Notify Moderator
Your chassis maker AND Newmar would be the source for that information. Either company could have diminished towing capacity from the 10k.
Far better sources than our speculation.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
way2roll
Wilmington NC
Posted: 09/24/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Seems like if they could have given the MH the 10k capacity they would have. I agree, have to check with the manufacturer. Often simply adding a bigger hitch does not always equate to everything else being able to support it. (chassis, brakes, tranny, etc)
fyrflie
Martinez, CA. USA
Posted: 09/25/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Your answer is in your posted numbers.
It may be possible that the manual is a generic version printed for several different models.
Possibly have the hitch inspected to confirm the size.
Either way, use due diligence to confirm everything prior to towing over 5000 lbs.
tropical36
Southwest Florida_USA
Posted: 09/25/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Check with Newmar, but just the fact that it has a 10K towing capacity rating suggests that it also have a 10K hitch receiver.
This also applies to the tranny's capabilities, etc....
Our old coach had a very low tow rating and even though most everything was beefy enough for a 5K tow, the transmission wasn't up to it, being the weak link in the train. Still ran it all over the country, but had to be tricky and careful for climbing long 6% grades in hot weather.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Bobalooie
Canada
Posted: 09/25/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Are there different versions of Allison in these diesel pushers in that year? The option was for either a Freightliner or Spartan chassis (with Spartan having a 10klb buffer).
gatorcq
Arizona
Posted: 09/26/19 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Installed 2 support angle braces and weld in place.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
zb39
slippery rock
Posted: 09/26/19 06:20am Link  |  Quote  |  Print  |  Notify Moderator
What chassis? FL or Spartan?
Tiffin Zephyr(sold)
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
tropical36
Posted: 09/26/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
That being the case, it's most likely the Spartan that has an Allison 3000, at least. This should be reflected in the manual for either chassis and doubtful that they would print two separate publications.
dougrainer
Carrolton, Texas
Posted: 09/26/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Newmar installed 5k hitches back then. The Hitch rating involves 2 things
1. The rating of the actual Hitch
2. HOW the Hitch is installed/mounted to the Chassis Frame.
If the unit came with a 5k hitch, you will have to install a 10k rated hitch and have the Chassis frame beefed up to safely use that 10k hitch. Doug
