RV.Net Open Roads Forum: wiring harness for Ford F53 fuel pump
 > wiring harness for Ford F53 fuel pump
dalefuji
Milton, Pa.
Posted: 09/24/19 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have 1998 Holiday Rambler with 1997 chassis. I replaced the fuel pump and need the 4 wire harness to connect fuel pump to my existing wiring. The Ford part that I need is #F7PZ 9A213 CB and Ford no long has this harness. Apparently the wiring harness switches from one end of plug to other end. Motorcraft has part#WT56821 and they don't have part either.
Any suggestions as to where I could get harness or purchase one from Company that makes special harnesses that are out of stock.
Thanks
enblethen
Moses Lake, WA
Posted: 09/24/19 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Rock Auto
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dalefuji
Milton, Pa.
Posted: 09/24/19 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
already checked Rock Auto, no luck
garym114
Bluff Dale, Texas
Posted: 09/24/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Searched for AIRTEX 574620
https://www.rockauto.com/en/catalog/merc........ical-connector,fuel+pump+connector,13066
1492
Arlington, VA
Posted: 09/26/19 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
MountainAir05
New Mexico
Posted: 09/27/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
And if all else fails, make it.
allbrandauto
maryland
Posted: 09/27/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
check a dorman part number 692-251 see if it works for you
T18skyguy
Eugene, OR
Posted: 09/27/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Find a boneyard that carries that chassis. Here is a discussion of that part on IRV2.com
* This post was edited 09/27/19 06:27pm by T18skyguy *
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
PastorCharlie
NC
Posted: 09/27/19 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.rearcounter.com/F7PZ-9A213-BB-parts507605.html
https://www.amazon.com/-/es/dp/B000WI8AXE
