RV.Net Open Roads Forum: Tech Issues: 1996 Pace Arrow A/C Question/Help
 > 1996 Pace Arrow A/C Question/Help
DewLess
North Indiana
Posted: 09/24/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
96 PA that a/c has quit. Working perfectly before fueling up and then failure for rest of trip. Had a remainder of a/c pro can to apply refge fill. Gauge read to stop because compressor is not working. Attached is a picture of suspected parts which I suspect after checking wiring for rodent meals. local cannot[image] get to next week late
I do know function of these 2 pressure switches
Can anyone help ?.
* This post was edited 09/24/19 05:54pm by DewLess *
Mojave, Kern County, California
Posted: 09/24/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Twenty-three year old A/C? Replace all components IMO.
Ava
Vancouver Island. BC Canada
Posted: 09/24/19 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
One or the other look like a low pressure switches. If it detects low pressure, the compressor will not engage so as to not damage it. You can jump the wires together on a low pressure switch for a moment and if the compressor engages, the system needs recharging. Hope that is a start for you
haydoracin
north central, Illinois
Posted: 09/25/19 05:36am Link  |  Quote  |  Print  |  Notify Moderator
On my 1995 Chevy Blazer when the mechanic jumpered across the pressure switch with a paper clip and the compressor started he replaced the switch. Working fine since then.
Hayden & Jan
1994 Southwind 33L P-Chassis 454
2006 Chevrolet HHR
OTY (Mini Dachsund)
Chrisatthebeach
The beautiful low country of South Carolina
Posted: 09/25/19 07:12am Link  |  Quote  |  Print  |  Notify Moderator
The one on the left appears to be the low pressure switch.
Unplug and jump the two with a paperclip, that will make the compressor start and the refrigerant will fill.
Just because it is old does not mean it all needs replacement, I use a 1996 Explorer as my beater and it still has cold air at 300k miles.
Chris & Dianne
Jayco Designer 3110 SOLD 6-11-2016, looking for the next one.
F250 PSD 4x4 Crew Cab
DewLess
North Indiana
Posted: 09/25/19 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Very good information so far, I must have a switch/sensor further up-line to cut power to pressure sensor . I have no voltage at sensor plugs nor does a/c button on dash control thus thinkin of mouse food. Access to heater box is next step to find a switch
RLS7201
Posted: 09/25/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
You have a Denso HVAC system. In the link click on downloads for wiring prints.
Also in that era of Ford chassis, Ford left a connection for the AC behind the dash, up high. Fleetwood put an inline 20 amp fuse on that wire for the AC.
If you need to get into the heater/AC compartment, just look for the 4 screws in the kick panel forward of the passengers feet.
Richard
* This post was edited 09/25/19 10:54am by RLS7201 *
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
RLS7201
Posted: 09/25/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Nice to see a little humor on the forum.
Richard
DewLess
North Indiana
Posted: 09/25/19 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Richard
THX Richard for the link, those schematics are what I was needing. Some honey doos have come up with mh goin on back burner. Not so bad I suppose with house A/C going.
DewLess
North Indiana
Posted: 09/25/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
At 23 years old does not mean all parts are original, The Old Girl has been nice to me,
