RV.Net Open Roads Forum: Can't figure out how to grease u-joints - '93 Ford E350
 > Can't figure out how to grease u-joints - '93 Ford E350
rgnprof
Oklahoma
Posted: 09/24/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I had new u-joints installed last summer on my Class C Ford E350 and I went to grease them and can't get to 3 out of the four (only one I coulod reach was the front). c I bought a new 'right angle' connector and still can't connect to the zerk fitting...
Is this an installation problem? Can't figure out why they would make serviceable u-joints with zerks that you can't reach and "service"...
Any thoughts?
enblethen
Moses Lake, WA
Posted: 09/24/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
It could be simply a rotation problem. Block wheels a few inches, roll rig slightly to get fittings to an accessible locatiom
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Nv Guy
Reno NV
Posted: 09/24/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Company that made U joints probably isn't the same as who made the driveline yokes.
As mentioned, you may need to rotate the driveline so there is some angle to the U joints, which will provide clearance to get the grease gun in.
rgnprof
Oklahoma
Posted: 09/25/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Spicer replacement U joints...Have tried rotating driveshaft, etc.
Was hoping for some recommendation for a new, really thin walled zerk connector fitting [emoticon]
Thanks!
enblethen
Moses Lake, WA
Posted: 09/25/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
These mini grease guns have a much smaller connector to the Zerk fittingsMini grease gun
amxpress
Clayton, NC
Posted: 09/25/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Try an adapter like this:
Grease gun tip
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L is out of state, out of touch, and out of her mind
shastagary
minnesota
Posted: 09/25/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
one of these may work Right Angle Grease Coupler
bukhrn
Lanexa, Va
Posted: 09/25/19 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
X2,https://www.google.com/search?q=needle+g........7j0l4.13323j1j8&sourceid=chrome&ie=UTF-8
2007 Forester 2941DS
2014 Ford Focus
enblethen
Moses Lake, WA
Posted: 09/25/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
OP tried the swivel style coupler. Those are very large Zerk fitting end
theoldwizard1
SE MI
Posted: 09/25/19 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Lincoln Lubrication 5803 Grease Needle Nozzle
The picture does not show it, but it should have a soft rubber tip.
How to Grease U Joints With A Needle Nozzle
