RV.Net Open Roads Forum: Toy Haulers: Water Heater Problems
Search only in Toy Haulers
 > Water Heater Problems
SMarquez
Rancho Cucamonga, Ca
Posted: 09/24/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Atwood water heater that has been acting up for a while now and I hope you can help. It is a pilotless unit if that makes a difference. When I first turn the WH on it takes a couple attempts to light and everything is fine. After 6-7 hours it shuts off and I get the red light at the switch and it won't relight. Once in a while it will try but it seems to struggle and will back fire with a nice POOF that is a little alarming bit doesn't ignite. If I shut it down for a couple hours it will light up like normal. I have taken to just shutting it off when we're not using it but I hate when my stuff doesn't work as designed. I took an air hose to it and got some dust and fine dirt out of it but I lit it up left it on evernite and it shut itself off again. I'm thinking it may be the igniter, maybe it is intermittent or are they a good or bad function only?
Thanks.
garym114
Bluff Dale, Texas
Posted: 09/24/19 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Try checking the burner, should do it each season.
https://yourfulltimervliving.com/rv-reso........g-simple-maintenance-will-save-you-money
SDcampowneroperator
South Dakota
Whats your altidude? Altitude makes a difference in % of air to gas mix, so a lean or rich mix will cause mis fire. When it does light what does it sound like look like?
A roaring flame is lean, lazy lean, quiet, yellowish. Clean blue with slight rumble is proper.
We have had to adjust the air intake (with tape over a bit of the intake) at low altitude to stop flame out from low mixture.
SMarquez
Posted: 09/24/19 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
I went through all this tonight. Like I said, it works fine for the first 6-8 hours or so then shuts off. I shut it off for a while and then it works again for another 6-8 hours. I guess a better description is that it is not cycling like a regular heater.
SMarquez
Posted: 09/24/19 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
I'm at about 1500'. Everything looks good. Just seems like it won't cycle back on when the water temp drops after the initial start up.
Rover_Bill
NE. Ohio
Posted: 09/24/19 11:41pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the thermostat may be going bad and the ECO may be shutting down the gas flow. See this for a nice visual troubleshooting/replacement guide.
2015 GMC Canyon 3.6L V6 4X4 TowHaul SLE ExtCab Bronze
2016 Keystone Passport GT 2670BH
ReCurve R6 hitch, DirecLink brake controller
2005 Suzuki C50 2006 Suzuki S40
Old-Biscuit
Verde Valley
Posted: 09/25/19 12:10am Link  |  Quote  |  Print  |  Notify Moderator
Flame not relighting when t-stat calls for heat (over 6-8 hours it would cycle SEVERAL times) is #1 reason RED Fault Light comes on
If thermostat was going bad it would either NOT heat at all or would overheat
ECO would then trip and lockout water heater (trigger the RED Fault Light)
What year is this water heater?
Sounds like the circuit board is causing problems.....which Atwood boards have an issue with
nayther
Burbank, CA
Posted: 09/25/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
can you hear the spark igniter "clicking" when it tries to light?
I'm with Old-Biscuit, seen quite a few boards being replaced.
Year of TH would be helpful
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
momentum rv
Central Cal.
Posted: 09/25/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
The gap in the ignighter may be too close or too far. Either one can cause your problem. Try adjusting it slightly further to get a stronger spark.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
SMarquez
Posted: 09/25/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I can hear the igniter clicking. It will sometimes "backfire" but not light unless I shut it down for a while.
