RV.Net Open Roads Forum: Beginning RVing: Splendid Washer/Dryer
 > Splendid Washer/Dryer
Kevarino
No Cal
Posted: 09/25/19 12:57am Link  |  Quote  |  Print  |  Notify Moderator
What is the trick to get non wrinkled clothes from the Splendid Washer/Dryer?
Kevin and Barbara
2007 Winnebago Tour 40 TD
Cummings ISL 400
2chiefsRus
USA Somewhere
Posted: 09/25/19 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Take the clothes out between wash and dry cycle and shake them out. Separate loads - i.e. washer loads can be twice as large as dryer loads. I tend to hang dry as many clothes as possible such as tee shirts and light weight shorts. Don't buy clothes that wrinkle easily. Don't use too much soap.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
jplante4
Cape Cod
Posted: 09/25/19 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Also, drop one of these in an empty load every once in a while. The hoiles in the drum get plugged up and inhibits the airflow.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Scottiemom
South Dakota/Indiana
Posted: 09/25/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Too many clothes and too much soap are the biggest culprits. I recently did a load and the stretch jeans came out so wrinkled they were unwearable. I put them back in with one other item and rewashed them without any soap. Came out perfectly.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
Big Katuna
Deland, FL
Posted: 09/25/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
We use a little fabric softener and add two dryer balls after washing and also shake the clothes between wash dry.
My Kharma ran over my Dogma.
Kevarino
No Cal
Posted: 09/25/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Thank You All.
I’ll try all of these hints.
Kevin
ependydad
Here and there
Posted: 09/25/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
We use fabric softner and dryer balls but don't take clothes out between wash + dry.
Load size is also important.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Big Katuna
Deland, FL
Posted: 09/25/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Yes load size is key.
I would also add that there is a trap on the lower right front behind the bottom trim. that should be cleaned annually.
It’s not a lint filter. More like a coin trap. I never checked mine in ten years and this summer the unit started acting up; not rinsing right. Read the manual and cleaned it and there was three quarters, a few nickels and some pennies.
rdhetrick
Posted: 09/25/19 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
After wearing pressed and starched shirts for so many years, I love the look of wrinkles!
Rob
2005/06 Mandalay 40E Full Time
2015 Jeep Grand Cherokee
2oldman
New Mexico
Posted: 09/25/19 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Remove from Splendide and hang.
